questions
MA
questions
I am thinking of getting a nitro boat. I have been runing nitro trucks for about a year.
I think i''m going to get the Miss Vegas. Will the Vegas handle choppy water?
What are some of the things to do to retrieve a boat out in the middle of the
lake? How often do you have to replace the prop?
TX
RE: questions
ORIGINAL: madmax93
I think i''''m going to get the Miss Vegas. Will the Vegas handle choppy water?
ORIGINAL: madmax93
lake?
lake?
ORIGINAL: madmax93
Sean
RE: questions
I have found after many trips out in a dinghy to get a boat best to keep to swallow water lol
i bought waders great things and a fishing rod telescopic one fits in boot of car very handy
MA
RE: questions
I just ordered a miss vegas and I have another question. What happens when the
boat capsizes? Does the engine take up water or is it sealed from water getting up the pipe etc.
My Feedback: (12)
SC
RE: questions
ORIGINAL: madmax93
Of more importance than the engine, if the boat has been upside down in the water, you should remove the radio box cover to confirm it's still dry.
My Feedback: (12)
SC
RE: questions
ORIGINAL: madmax93
I have a HPI truck radio, will that work with the Miss Vegas or do you need a radio with the steering rate knob?
MA
RE: questions
Is there a trick to get the flex drive in the coupler, like loosing the engine? I ruined a flex drive shaft by forcing it in because it would not go in.
TX
RE: questions
ORIGINAL: madmax93
I too had to do what Dan said...and twist my cable while installing it in the version 2 collet. The version 1 collets wore out pretty fast and folks were losing cables/props. I think they OVER corrected this problem withe the Version 2 collet...making it too tight...which makes it hard to get the cable into and out of.
Sean
MA
RE: questions
I have yet to run my Miss Vegas because I'm waiting on a flex shaft from Tower hobbies. I would like to know about how long I can run on one tank of fuel with it being rich for break in?
RE: questions
About 5 mins. bring it in and turn engine so piston is down let it cool off , refill with fuel and go again .Do this three times and then start leaning 1/8 turn until it will just get on the pipe and leave it there, keep checking all the screws for tightness and above all have fun. oooops when you are done for the day clear all fuel from the engine and put some afterrun oil in and a couple of pulls on the starter.
MA
RE: questions
What type of glow plug does the Miss Vegas use? Is it a long or short plug, medium, hot or cold? I am limited to what my hobby store carries, so I might not be able to get an O'Donnell's etc.
