amps f1
amps f1
hi just purchased a amps tunnel hull 29" long what size engine can i put in i have a 11cc k&b outboard and a 3.5cc k&b also where do you get the outboard engine covers from cheers chris
RE: amps f1
Post a pic so we can take a look. I would use a 3.5 to a 7.5. The 11 will work but will be a hand full. There is a guy on ebay that sells the OMC cowl. Take a look at the Amps thread running there is some good info on it.
RE: amps f1
I run an O.S. MAX 21 on a 30" tunnel and cannot imagine trying to run a boat one inch smaller with a 7.5 engine. But hey, you're free to make your own decision.
JD
JD
RE: amps f1
hi mate the hull i have is on page 7 of amps hull and outboards member neonweb amps (tm products) i have another hull with 3.5 k&b its32"long should i swap the engines ive tried posting picture but dosnt seem to be working cheers chris
