Miss Vegas w/stock OS 18TZ - Prop?
MI
Just curious what would be a good prop to start out with for my Vegas. I picked up an OS 18TZ (no mods) and will be running 30% nitro. I have the Grim turn fin and no sponson mods. I also have the strut modded with a deeper slot so it can be raised higher if needed. Stock drive cable with a 1/8" prop shaft.
Thanks in advance!
Thanks in advance!
RE: Miss Vegas w/stock OS 18TZ - Prop?
When I had mine I ran a octura 438 but this weekend at the winter nats I saw one running a y535 with a modded tz and sponson mods. It was really fast.
M440 with sponson mods radared at 48/49 w/TZ 18. You can make a slip fitting with a piece of 1/8ID brass tubing to adapt the 3/16" dia. props.
JD
JD
ORIGINAL: misshydro
Jerry,was one of your friends running a 215 on his vegas? I think it was socco72?
JD
ORIGINAL: ka350kaptain
Do I need to do the sposon mod in order to run the M440?
JD
WA
P215 does good on the vegas with or with out sponson mods that i found, my bro ran a 215 untill his motor was modded doesn't have the torque to spin it anymore, had no s mods and had some sayin dang and that boat is stock, worked pretty good on mine to with the TZ but the stocker likes it better i also ran a x637 with TZ with good results
VT
[link=http://www.youtube.com/watch?v=QSPJi7yBKyA]miss vegas video[/link]
edit I should note I'm running a cvr.18
MI
Thanks for the input guys. I will try the M440 without the sponson mods first. I also have a Y535 that I was using on the stock motor. Will try that as well.
