If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 3 of 3 FirstFirst 123
Results 51 to 59 of 59
  1. #51
    Dan S's Avatar
    Join Date
    Aug 2006
    Oromocto, NB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Mean Machine rebuilt
    Rock,
    if you have great and crisp response on the bench and dies in the water, chances are its too lean.
    I would start at 3 1/2 turn.
    try it and than if its too rich and you can't clear it out on the bench or in the water go in 1/8 at a time.
    Dan.
    F-41 Stryker Cat 260 Full Mod - Whiplash GV NFS 260 - FireFighter 18 - Miss Vegas CVRM 18
    Futaba FASST
  2. #52
    Rocket-J's Avatar
    Join Date
    Jan 2009
    Gilroy, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks Dan. I will give it a shot. It will be a couple of weeks before I get my prop from Mecoa.
    Rock.
  3. #53
    jcrosk's Avatar
    Join Date
    Sep 2006
    Hudson, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    So what happened withthe 7.5? I have a empty hull and I wondering how much engine I'm going to put un it. Ofcourse putting a .46 in there interst me greatly but I want to know how did it handle? Was it too much? Do you have video?
    Thanks[:-]
    What\'\'s the worst that could happen?
  4. #54
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Rocket-J
    In the beginning I talked about finishing this boat in Gel Coat. We spray Gel Coat on real boats and cover it with a PVA to allow it to cure. Then you must color sand and polish it. I have changed my mind on this model. I am in a hurry to get in the water so I am using spray enamel and a clear coat to protect it from the nitro. My past experiences say I will need to repair it from time to time.
    The photos show that I have finished the entire hull in white. The graphics will go on in several layers. I first draw out the pattern and use it to apply the masking tape. With a larger budget, I would go the the paint store and buy all the same brand, in the colors I want, and know everything is compatable. I bought spray paint at different stores, trying to get close to the colors I wanted. I have had some bad luck with compatability. I have more time than money, so I am just dealing with the issue. I recommend using all the same brand to eliminate the head aches. I am trying to come close to the colors of my real boat, and that is not easy.
    Rocket-J, what did you spray the interior with?
    Looks nice and clean
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  5. #55
    Rocket-J's Avatar
    Join Date
    Jan 2009
    Gilroy, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi Guys. It has been a year and a half since I logged on here. When I lose interest I lose interest. Once the build was done, I went to the pond once, wrong prop, never went back. Now I seem to have no opportunity or time for this boat.
    To answer str10, I use PPG low voc Speed Coat. It can be polished in about and hour.
    I am selling the 30" Cat with a 7.5 KB, Futaba Tx and Fx, servo sentry and stand. Also an Electric starter, hand fuel pump, extra new CY25 engine and all my spare stuff. End of my RC Boat come back. No time or interest. $300. About half what I have in it. I will save the pix for memories. Someone will get a lot of fun out of this. All it needs is set up and tuning. Al
  6. #56
    advanced builder's Avatar
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RJ the 2 1/2 turns seams small. We spent part of the weekend trying to get a almost NIB.21 CMB green head to start& run. 4 turns to start with then work down.I used a friends remote needle on my Zoom carb. I gave it back to him. without CKing the needle settings Darn it . The needle I brought with me had a broken off line barb. no good. I didn't bring the one that came with the engine, thanks : Jeremy123 We did get her up & running. with some help from friends. The Zoom Carb took some time to set up, now I got setup with a different needle I got my hands into the case & liner, she's fast Very fast ABmods ,or me I did it.Runs great until you put the cover on. gettin air to the engine ,she likes to overheat, I added more openings .
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1510881   Click image for larger version.
ID:	1510882   Click image for larger version.
    Stoney Pond Model Boat Club, Canandaigua, NY
    International racer
    http://neilsrcsite.shutterfly.com/
  7. #57
    Rocket-J's Avatar
    Join Date
    Jan 2009
    Gilroy, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    SOLD. Thanks for the memories.
  8. #58
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    here you go,We got the CMB green head up & running inside my MM18. She was a little fussy at first we ran her rich & lean out after a few tanks. finding the sweet spot. I have the Zoom carb 38mph ,we called her flipper, I did drop the strut down & negative AOA angle of attack. The engine was gettin on pipe. Prather pipe,was way to loud. I put on a Russian K-pipe to help with the noise. Joe Petro driving my hull. With a Joeprop x443 /2
    [youtube]http://www.youtube.com/watch?v=7whbJtOs3uc[/youtube]
    International racer
  9. #59
    Join Date
    Oct 2007
    Miami, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Sweet build it looks real good.Enjoy the engine buddy.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
