Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
7.5cc O/B tunnel hull set-up questio
Reply
Old 03-23-2009, 08:23 PM
Mogrits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 7.5cc O/B tunnel hull set-up questio
I've used the search feature but can't seem to find the right thread. Does anyone have a link to photos or text describing basic engine setup for a 7.5cc tunnel hull? I mean basic stuff, like the height to set the engine on the transom relative to the tunnel bottom and a starting trim angle (I understand these are unique to each hull but there must be some basic guidelines). I have such a boat bought used and the engine seems to be too high on the transom, i.e. the anti-ventilation plate is set much higher than the bottom of the tunnel.
Thanks.
Mogrits is offline
Old 03-23-2009, 09:55 PM
ob nut
ob nut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 7.5cc O/B tunnel hull set-up questio
Most of the current "race" boats out will always start around the prop line at 1/8" +/- above the spoon bottoms. With that, about 1 degree neg on the thrust angle. Start with that and work the setup. Also, the CG is around 27% to 33%. A X447 prop is a good starting point.
You might want to look at this thread: [link=http://www.rcuniverse.com/forum/m_6287289/tm.htm]7.5 tunnel thread[/link]
ob nut is offline
Old 03-23-2009, 10:29 PM
Mogrits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the thread link. I'll read it in its entirety. I'm not racing- just want to have a little fun with this boat in my pond. So, I'm a little behind on the phrases and nomenclature. Are you saying the centerline of the prop should be 1/8" above the bottom of the sponsons? I'm accustomed to full-sized boats where the anti-cavitation plate is normally even with the bottom of the hull. (These are not racing boats either)
Mogrits is offline
Old 03-24-2009, 12:29 AM
ob nut
ob nut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Mogrits
Yepper.. It's a starting point. Might need to go up a bit.
ob nut is offline
Old 03-24-2009, 02:37 AM
Mogrits
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Okay then. Instinct tells me to set this motor far too deep. I understand having it too deep will create too much drag but I'll start about 1/8" above the sponsons at the rear of the boat, with a slightly negative trim (bow-down). I'll take it from there. I did read the entire 7.5cc thread but apparently it assumes a level of knowledge I don't possess. Thanks for your help.
Mogrits is offline
Old 03-24-2009, 03:26 AM
ob nut
ob nut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Prop to deep - boat will "plow" thru the water. prop to high - boat will be "flighty".. The full size racing tunnels also run the prop half submerged. This allows the motor to rev up..
Good luck..
ob nut is offline
Old 03-25-2009, 07:17 PM
Lakeside518
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After taking sometime off I'm returning to the sport. Most of my experience has been with K&B's. I still have a 3.5 and a 7.5 both stock with SS sharpened and balanced props. Engines stock but with polished lower units. I always ran them on Deep Vee's.....
I decided to try something differant. I ordered a Rossi outboard with Tuned pipe from Hyperformance and a TX45 hull. I'm sure I will haev some Questions after I get the custom paint work done.
If someone can hook me up with a link to better inform me on where to mount the engine that would be awesome. Any info on desired Slip % How to achieve max RPM and potential out of this setup?!
I do not believe there is a local group of racers here. Back in the day there was but I don't think they exsist anymore! Does anyone knows of a group near Albany NY ? If not it will just be a recreational play boat like the rest.
Kris
Lakeside518 is offline
Old 03-25-2009, 11:43 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The club near Albany might be a NAMBA club. Check www.namba.com , if not try www.impba.net .
Ron Olson is offline
Old 12-08-2016, 03:39 AM
Rcthesecond710
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also have a vintage tunnel hull boat with a kb 7.5 engine. I recently just got into the boats and I ran the boat for the first time last weekend it ran great after running it I realized that the mounting plate for the outboard came loose I do not know where it originally sat now as it was fine where it was how do you adjust this and what are the guidelines that you go by any help would be great thank you
Rcthesecond710 is offline
Old 12-08-2016, 11:40 AM
ob nut
ob nut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After dropping off the face of the earth for 5 years, I myself returned back to running/racing my tunnels. With new boats, had some issues with adjusting the depth. Met a good man at a race this year that gave me some sound advice. Any tunnel, start the prop shaft angle even with the spoons with 1/4" above the line. Since taking this advice, never had a problem with a good starting point. This is for all tunnels and motors.
RIP Rick....
ob nut is offline
Old 12-08-2016, 12:39 PM
Rcthesecond710
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm new to the nitro boat scene. I recently picked up a vintage nitro boat with a KB 7.5. Its in pretty good shape but seems a little old. Lol. It will scoot that's for sure. What are the best upgrades for the kb 7.5 engines and what maintenance should have to be done on the foot of the boat engine ( lower unit). 20161202_115540.jpeg
Old 12-08-2016, 04:32 PM
ob nut
ob nut's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Best for any motor are new bearings, seals/gaskets. Turbo the crank, clean up the cylinder ports for better flow. The lower needs a sharp front and flat bottom. The bottom should be close to how the boat will run. Believe it or not, it is a running surface. Shorten the length of the skeg if the boat turns easily. If it's too short, boat won't turn. Set up an oiler for the lower. Or at least make sure the cable is well greased or oiled for each run. Starting props would be X447 or X448.
For more power, get a pipe: Silver Bullet, Equi, SPP, Irwin, etc...
ob nut is offline
Old 06-29-2017, 08:53 AM
joe monohan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
this is probably late but you can try 707specialties.net , namba707spec@aim.com , joe
joe monohan is offline
Old 07-22-2017, 09:19 AM
Jaymanaa@lak
Jaymanaa@lak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just curious, is this a really old thread? Where are you guys buying speed parts, or even Rossi outboards. I've seen a picture of a home made Rossi OB, but have never seen a complete factory one?
Jaymanaa@lak is offline
Old 07-22-2017, 12:13 PM
Ron Olson
Ron Olson's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nova Rossi is getting ready to roll out a new one but most OB manufacturers are only selling the powerheads so you'd need to use a K&B or Lawless lower. It's a good question though as to why they don't.
Old 07-22-2017, 12:33 PM
joe monohan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can email me namba707spec@aim.com
or call 909-838-6158
707specialties.net
i am just about the only one the work with K&B ect.
joe
Old 07-22-2017, 12:42 PM
joe monohan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3.5 , 7.5 , 11.0cc tunnels Q & A and parts
you can email me namba707spec@aim.com 07/22/2017
707specialties.net
i am just about the only one the work with K&B & NOVA - ROSSI
joe
Old 07-23-2017, 05:00 AM
Jaymanaa@lak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, at least I'm not going crazy. I looked at the Nova site and they listed an outboard, but no stock for sale, and no picture of an outboard. I do have a few K&B lower units that are just laying around, but no spare Rossi heads. The thing I wonder is this; I would assume the attraction of using a Rossi head would be higher RPMs without losing rods. That makes me wonder how much abuse the K&B lower units can take? The trick would be some kind of way to couple the head to the lower unit and still leave a means of starting. Thanks for the link Joe, I appreciate the help. I have a 46 Prather deep Vee with a Rossi (inboard of course), and really like that motor. Plus I love to tinker and just retired this last year after 37 years of pipe-fitting, so a hybrid outboard project might be the ticket.
Old 07-23-2017, 05:08 AM
Jaymanaa@lak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, FWIW, if you just have to have some Italia power, looks like around 4 bills will get you turn key here.
Hobby Supplies CMB Engines
Old 08-10-2017, 11:30 AM
Jaymanaa@lak
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I didn't mean to take this thread OT. For what it's worth, I like my tunnel hulls set up so I can sit them in the water, hit the throttle and they jump up and land on plane. I like about 3 or 4 inches of boat in the water when it's running flat out with the prop doing the rest of the heavy lifting. I'm getting ready to start experimenting with wings, as I'm tired of catching a little wind gust and flipping the boat, grrr.
Reply
Display Modes
