THUNDERCAT 31
FL
RE: THUNDERCAT 31
Yup they do good props. Spend the money on the B&S prop if you can't do it yourself. It will give you Much Better Performance, and an Unbalanced prop will rattle the strut apart,,Literally,, then your Prop, Shaft, and All are at the bottom of the pond. Spend a little Now or spend A Lot Later.
TX
RE: THUNDERCAT 31
I did...for my boat...and no regrets. To me...sharpening and balancing is all good.....if yu have the tools and the time. If you don't.....pay someone else for their time and make sure they are reputable. I got mine from OSE as well....prop BITES HARD....tore up my flexshaft !!!!
ORIGINAL: Owen18
Thanks you very much for the info Ron. I dont think that I am going to get a prop balancer because this is probably the only prop change that will take place for my thundercat. I just dont have a huge box of props like you do haha. Do you think that it would be a better deal for me to buy the already sharpened and balanced prop from this dealer?
http://www.offshoreelectrics.com/pro...rod=octsb-m445
Thanks Owen
Thanks Owen
BC, CANADA
RE: THUNDERCAT 31
Thanks guys for that info, I think you right a B&S prop should be better for me cause Im not wanting to be replacing shafts and such when I screw up on balancing it!
Thanks Owen
Thanks Owen
#31
BC, CANADA
RE: THUNDERCAT 31
Hey guys here are some pics of just my stock thundercat. Nothing too special, Reason for posting these is because I was hoping that someone could tell me the prop that is on it, I know it will be hard but just a guess is helpful. I was just wondering what prop they have from the factory.
RE: THUNDERCAT 31
No idea of what it is but plastic props don't get it on nitro boats. I talked to IMPBA president at the time Bill Zuber about the use of plastic props on nitro RTR and the fast electric boats about how dangerous they can be. Shortly afterwards a new safety ruling was put into effect that racing boats for any nitro class and fast electrics over a certain amount of power were not allowed to use them. Yeah, blame me!
OK, back to your prop. I don't know what the size is but it appears to be too small for your boat. I want to say that the Prather 235 was the prop originally supplied with the boat. Between the time that Terry Prather shut down his business and Hyperformance bought the tooling and molds Pro Boat had problems getting props.
#33
FL
RE: THUNDERCAT 31
The stock prop is basically the smallest and lowest pitched prop they can use and still be able to push the boat with minimal slippage. It makes it easier on the engine during break in. I believe it's a plastic copy of a Metal Prather Prop (230 I Think).
#35
BC, CANADA
RE: THUNDERCAT 31
Alright thanks, sound like I am in need of a new prop, haha so do you think I will notice a huge difference between the prop I will most likely get (Octura M445) and the prop that is on this boat?
#38
FL
RE: THUNDERCAT 31
Man I hear ya, it's hard for me to get much of anything done during the day lately our temps have been 95 to 100 and humidity goes from 50% to 80%,,[:-] and my shop is like an oven. I was breaking an engine in the other day and pointed my temp gage Outside and it was 99*F, I pointed it Inside and it was 104*F. With a sprinkler on the roof and 2 big fans going.
So I gotta go in Spurts,,LOL,, an hour in the shop and it looks like I just climbed out the pool, I get more done after the sun goes down then I do in the day time.
#39
TX
RE: THUNDERCAT 31
Let me clarify.....when I said I tore up my flexshaft, it was because the stock shaft wasn't designed for the metalB&S prop I purchased. Another forum member went thru 3 of them.....the stock shafts came with plastic props. When you start upgrading.....beprepared to upgrade multiple parts together if you can as stock parts may or may not hold up to the stress of the better installments.
ORIGINAL: Owen18
Thanks Owen
Thanks Owen
#40
NY
RE: THUNDERCAT 31
that in fact is only partially true tho....some had theirs come apart or break because of poor workmanship in the making of the flex shaft......more often than not, it was broken due to misalignment of the flexshaft and coupler/engine, or because they installed an unbalanced/unsharpened/unpolished prop, which caused way too much vibration and caused more failures throughout the boat not just the flexshaft.......ive read all the threads for the sv27....nitro or electric version......and those conclusions only come from seeing all the flexshaft failures in the threads, and why they happened....only few were caused by ones that were 'too short'....a majority tho, and not just to the SV but in other boats as well, were caused by lack of or not enough lubrication of the flex shaft so they just plainly 'wore out' extremely quickly.... these mentioned failures w/ exception of poorly made flexshaft, are common mistakes made, and it doesnt matter if it was a stock or the best aftermarket flexshaft you can get, will cause any flexshaft to come apart or break
#42
NY
RE: THUNDERCAT 31
true enough ron....but forthe most part, ive covered that aspect i think, in the first sentence tho with
from the TC, shockwave, SV, and U-18 threads ive been reading, not many had failures due to solder wicked up from thebuyers actually cutting down and doing it themselves on an aftermarket.....it was theRTR-installed flexcable that had too much wicked up in assembly in most of the cases posted and even then, i only read that posted a few times total... more often in the threads tho the shaft had broken off in middle of the stuffing tube which would suggest wear from little or no lube...not everyone in these threads is lubing up their shaft every couple orevery few runs, not everyone'shonest about it either. its human nature......... most of the 'hobby buyers' getting started in the hobby arent going to be meticulous about checking out or going through their boat before and after running them. most are going to buy, bring home, maybe read the manual and put it in the water without even checking things over first...let alone, flex shaft maintenance..even some of the experienced modelers will forget once in a while...... even ive done similar without thinking about it..bought an rtr heli, put it in the air without checking it over first, crashed it and found out afterwardsthat all of the servos were reversed..and ive quite a few heli's in my hangar, had 6 ive been flying before that incident...
#43
RE: THUNDERCAT 31
I've been seeing members looking for sharpened and balanced props for these boats so I left a message for Andy Brown from www.cmdracing.com as he's getting back into doing this service again, reviving the Prop Wall on his site. I let him know that there is a demand for Octura M-445's so hopefully he will stock those.
#45
NY
RE: THUNDERCAT 31
I finally recieved my Speedmaster rudder assy from Aeromarine Laminates....took them a while to get it out to me because all the Speedmaster gear was on back order. sad face tho, they sent me the single pickup version when i ordered the dbl pickup one....no real biggie they were close to if not the same price at the time....i'll use the one i was sent, and can order just the rudder separately anyways and try it out later...i have to have those mounting holes adjusted and set up before i can paint the hull anyways, now have to find the time, especially with my screwy work schedule :P
Ah b4 i forget, Ron, i may try out your suggestion (once the boat running season is over) and replace the engine with either that Rossi you mentioned, or their .35.....i have to have a bit of fun with the stock one first tho
#46
TX
RE: THUNDERCAT 31
Ok.....Got my OSE upraded shaft today....fast shipping! Installed it....noticed a plastic tube in the stuffing tube. The new shaft came with one as well.....is this required?Can I not use it and just use more grease on the new shaft?
#49
RE: THUNDERCAT 31
You might be better off trying to replace the liner then. The trick is to stretch it first then cut a little bevel on the end that gets inserted first. It's better nowadays to not use a liner but with it already having one in place, runing without it will make the cable whip around inside the stuffing tube plus water will find its way up the tube.
