Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
AQUACRAFT'S NEW MISS VEGAS U-18 "The Deuce" Thread
Reply
Old 08-02-2009, 08:45 PM
  #76
TrEsPaSS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AQUACRAFT'S NEW MISS VEGAS U-18
hey all... today was a great day! .32 installed, broken in... and smokin! will need some help with sponson mods... need to keep her in the water.
http://www.youtube.com/watch?v=WdC4uERM6cY
TrEsPaSS is offline
Old 08-03-2009, 01:36 AM
  #77
JLB7569
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, I had the same problem with mine. I got rid of the stock tank and installed a new Hayes 13 oz. airplane tank. Since I've replaced it, I haven't experienced those problems anymore and I don't have to worry about fuel getting all over the front end of my boat. I also can run my boat for another 5-6 minutes longer. I was able to utilize some of my old nitro plane stuff too. It's kind of nice to fuel your boat with an electric fuel pump and if you don't burn all of your fuel, you can just use the pump to pump it back into the fuel container. No more messes this way either!!! At first, I thought that a 13 oz. fuel tank would be to big and heavy for this kind of boat. I haven't noticed any difference in how the boat handles and I like how much better it runs now.
JLB7569 is offline
Old 08-03-2009, 03:02 PM
  #78
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
13oz, awesome run times!
What is your total run time with that tank?
srt10 is offline
Old 08-03-2009, 08:40 PM
  #79
TrEsPaSS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: JLB7569
JLB would it be possible to see some pics, I am interested on how you mounted the tank.. thanks
TrEsPaSS is offline
Old 08-05-2009, 07:42 PM
  #80
tbmiller60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got my Miss Vegas Deuce last Monday and broke the engine in over the weekend. I noticed in the review by RC Universe that to gain some more speed that you should switch 50% nitro. Will this shorten the engine life or harm the engine in anyway? Currently running 30% nitro with 18% oil content. Thanks for the Help
tbmiller60 is offline
Old 08-05-2009, 10:03 PM
  #81
toyotatruckin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran 40% across all my motors ive tried less and more, but found the 40% to be a good middle ground between hot and not, between 40 and 50 you wont see enough if at all to justify the extra cost and extra needle work youll have, there are so many ways to pull more speed from a boat than just jumping to a higher fuel %
toyotatruckin is offline
Old 08-05-2009, 10:52 PM
  #82
Dan S
Dan S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike is right.
you will see a big difference from 30 to 50% however.
myself, I use 35%
Dan.
Dan S is offline
Old 08-06-2009, 04:59 PM
  #83
SUINC
SUINC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I've got an octura coupler to replace the pathetic soft metal coupler that comes with the vegas. The shaft material is pretty hard, so use a good die for threading. Has anyone ever reamed out the 1/8 props to 3/16? I don't see why it wouldn't work.
Here is the rudder I bought:
http://www.offshoreelectrics.com/proddetail.php?prod=tfl-502b20-black
If the bracket turns out to be too long I'll shorten, but I'll give it a shot first. I agree that the aqua rudders are very brittle. I've been through two of them until now.
My
OS won't just bolt up, unfortunatly (21vz-m) Got a good deal on one that I couldn't pass up!
How did this rudder work? I'm new here and to boats, a buggy/truggy racer but looking to have some fun with MV2. Just got the MV2 in the mailyesterday and will break it in over the weekend. I plan on leaving it stock for the break in, but will have a turn fin and prop ready to bolt on. Any other advise would be appreciated!
Thanks!
SUINC is offline
Old 08-07-2009, 07:47 AM
  #84
f16man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see that the duce comes with the old plastic props,,,,,,, I really think that the prop would be the first thing to go not only for performance reasons but for engine protection,,I can see a poor newby loosing the blades on the prop in a wide open throttle run and ruining the day of fun at the pond due to a connecting rod or other engine failure. So in short for all you new guys order the grim prop along with the boat and round file those plastic props you will be glad you did...........................
f16man is offline
Old 08-07-2009, 04:07 PM
  #85
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone with some GPS numbers on a sock MV2 ?
srt10 is offline
Old 08-07-2009, 07:08 PM
  #86
kilr95ss
kilr95ss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a rooster tail coming off my rudder, is this because it is too long?
kilr95ss is offline
Old 08-07-2009, 07:51 PM
  #87
Sean Bowf
Sean Bowf's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kilr95ss
The second release of the orginal MV had a problem some times where the rudder mounting bracket was hanging down below the transom. You either hand to sand the bracket down, or move the rudder to fix it. I have not heard of this with a deuce yet..but you might want to make sure your bracket is not hanging below the transom on your boat.
Sean
Sean Bowf is offline
Old 08-07-2009, 08:34 PM
  #88
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kilr95ss
The rooster is caused by your prop!
If you take a picture of your boat at WOT you can see the blade pitch from the prop in the rooster tail
srt10 is offline
Old 08-07-2009, 08:41 PM
  #89
kilr95ss
kilr95ss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nah, this is from the rudder, this rooster tail is to the side of the main roost. Well, it's more like a stream than a rooster tail, like what comes from a "Sea Doo's" tail, squirting almost straight up.
kilr95ss is offline
Old 08-07-2009, 08:48 PM
  #90
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kilr95ss
Nah, this is from the rudder, this rooster tail is to the side of the main roost. Well, it's more like a stream than a rooster tail, like what comes from a ''Sea Doo's'' tail, squirting almost straight up.
No from the prop
not a MV but you can see the chop of the prop
the rudder only give a tad of light spray, and you can see the pitch of the prop all the way through the tail!
see doo's have a jet that causes a roost, no rudder on PWCs
srt10 is offline
Old 08-07-2009, 09:03 PM
  #91
toyotatruckin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check your water line see if its cracked, pulled off, etc.
Quote:
ORIGINAL: kilr95ss
Old 08-07-2009, 09:20 PM
  #92
kilr95ss
kilr95ss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sean, the rudder bracket is above the bottom of the transom.
toyotatruckin, no cracks, new line just put on. I did notice that in the turns, the water from the cooling line out the side of the hull is not steady, like as the hull slides through the turn the water pick up in the rudder is coming out of the water, but the stream from the rudder is still there.
srt10,I know sea doos are jet drive, this is a stream of water coming from the rudder. Looks just like the stream in this pic:
I'll try and get a pic of it tomorrow.
kilr95ss is offline
Old 08-07-2009, 09:25 PM
  #93
stackeddeck
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
is the stream of water from the jet ski not the water that comes out of the water-cooled engine... even when jet skis go slow some shoot up water like that
Edit: misunderstood you killr, thought you were saying the sea doo's spray was from its rudder (nonexistant rudder on a sea doo )
stackeddeck is offline
Old 08-07-2009, 09:29 PM
  #94
kilr95ss
kilr95ss's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: stackeddeck
I think it's a visual clue that the engine is circulating cooling water.
kilr95ss is offline
Old 08-07-2009, 11:50 PM
  #95
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: kilr95ss
Great you post that picture... I sold PWCs a few years back and that stream of water is for a greater visibility to other boaters on the water, it is not a rooster tail
It is a safety thing!
this is caused by a tube running from the jet drive, and it can be taken off to give a tad more performance...
srt10 is offline
Old 08-08-2009, 12:29 AM
  #96
toyotatruckin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
so far weve crossed off bracket being to low,water line, or fitting is not the problem, kicking the blade forward or back would not cause the "roostertail" got a video, I want to see the sucker spray lol
Old 08-08-2009, 10:33 AM
  #97
bmguidry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just recieved my boat back from hobby services getting the starter replaced and i can't seem to get the idle to go down i can see while in neutral that the carburetor is open to much and even with the throttle trim it's not closed enough and i tried adjusting the idle screw and it's not closing it enough any suggestions?
bmguidry is offline
Old 08-08-2009, 10:57 AM
  #98
srt10
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: bmguidry
adjust your servo arm or linkage, also is your HSN set correctly?
srt10 is offline
Old 08-08-2009, 11:23 AM
  #99
Dan S
Dan S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with srt10,
check your linkage, they had to take the engine out to service it and it is very possible when they re-attached the linkage to the carb they may have put it back into the wrong hole.
Dan.
Dan S is offline
Old 08-08-2009, 11:56 AM
  #100
bmguidry
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your help. I already posted above why i sent it in but I'll say it again it was sent in because the starter part on the motor wouldn't spin the engine over. I had to pay the shipping to them they fixed and it shipped it back under warranty. I got it back yesterday i started it 2 times today and it was running good after adjusting the idle and now it's doing the same thing the starter won't spin the motor i don't know what the deal is but it's pretty frustrating to have the boat 2 days have to return it have it 1 day and start it two times and it's broke again.
bmguidry is offline
Reply
Display Modes
