If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 126 to 150 of 385
  1. #126
    Join Date
    Jan 2008
    Mentone, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: AQUACRAFT'S NEW MISS VEGAS U-18
    Hello, I think around 10 to 12 minutes. I removed the stock glassed over wood blocks with a dremel. Placed the 13 oz. tank about 1/4" from the engine and centered it up from side to side and then took a black sharpie and marked where it was. I then took a 1/4" piece of square balsa stock and cut 2 pieces the length of the tank and made sure that the tank would fit down between them and then I epoxied them on the outside of the black lines that I had marked earlier. After that, I took another piece of balsa stock and cut another piece to join between the other two and epoxied it right behind the engine. With this done, now the tank won't move. I then took a dremel and drilled 2 holes in the pieces of wood on each side of the tank. I drilled these holes about 3" apart and then screwed little picture hanging hooks into those holes. Now all I had to do was to take 2 rubber bands and attatch them so that they would secure the tank from moving. Then, all you have to do is plum your fuel lines. I'll try to send some pictures on here of what mine looks like.
  2. #127
    Join Date
    Jan 2008
    Mentone, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I will try to put some pictures on here sometime.
  3. #128
    Join Date
    Jul 2009
    Morgan City, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I'm tring to fix my starter part on my engine like the guy from hobby services said my most likely problem and i can't seem to find the part he was refering to in the engine break down it's number 37 and number 38 here is some pictures of my open engine does anyone know if the parts are pushed in and where the red arrow is pointing?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	1253986   Click image for larger version.
ID:	1253987   Click image for larger version.
  4. #129
    Join Date
    Oct 2007
    Grove City, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    After having water in my boat, I decided to fill the bath tub and see just where the water was coming in at. Not relizing just how low the boat sets in the water, turns out that the water was coming in from around the exhaust which I noticed is completely under water . Is it just me, or does the exhaust being under water seem a little weird? Granted, wide open, I'm sure the exhaust isn't under water but slowing down or brining the boat in to the shore, it surely has to stall the motor,,,,,,,,doesn't it? Design flaw?
  5. #130
    Join Date
    May 2006
    Lakewood, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: pfireproof
    The transom exhaust is not exiting into the water even at a slow speed. If you are concerned about water entering the hull around the exhaust opening, dab silicone glue around the rubber exhaust tube where it exits the transom. Unless there is a considerable amount of water in the hull when it is running some water in the hull is not a performance issue.
    JD
  6. #131
    Join Date
    Oct 2007
    Grove City, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the info. I did put sealer around the exhaust. I just thought it was kinda funny that while the boat was sitting in the water that the exhaust pipe was under water.
  7. #132
    Join Date
    Jul 2004
    cedar falls, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I believe that there is a pin that is inserted in the crank journal in which the spring loaded plate grabs against.
    Regarding the water stream discussed earlier, I'll bet that it is coming from the gap between the strut and the transom. plug the gap with something, like a piece of foam and see if it quits.
  8. #133
    Join Date
    Jul 2009
    ft worth, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I blew my stock motor probably due to impatience in breaking in after a gallon of fuel.This deuce is my first boat and has me hooked on r/c boating.Iv'e decided to replace the stock motor with the O S TZ .18.Just a couple of questions,do I need the slide or rotary carb and what header pipe combo would fit well in this hull.I've read the motor will bolt right in the stock motor mount's
  9. #134
    Join Date
    Jul 2009
    Morgan City, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I think i just go from one problem to another lol... I got the motor fixed that red arrow was pointing at the starting pin got it out with a magnet and put it back together now to the new problem... Does anyone know the size or where to get replacement screws for the transom the part that holds the metal part that holds the shaft see pic i guess they were lose maybe and fell out while running the boat
  10. #135
    kilr95ss's Avatar
    Join Date
    May 2006
    Clanton, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    When my rudder mount bolt hole stripped out, I just drilled them out to accept some 8-32 bolts w/ lock washers. Dont have to worry about them coming out or loose.
    Charles Spradley
    When in doubt, GAS IT! This will either fix the problem or end the suspense.
  11. #136
    kilr95ss's Avatar
    Join Date
    May 2006
    Clanton, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    To replace my broken rudder control horn, I scrounged up some material at work and TIG welded it together, then drilled and tapped it for the shaft and set screw:
    Charles Spradley
  12. #137
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Nice job!
    first to own the Mini Slash!
    Amsoil Dealer.. 6XL Revo, Baja 5B, Losi8T, PS295, UL-1, AQ MC, OM29, DF33
  13. #138
    Join Date
    Nov 2005
    MANTECA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Probably 3mm screws on the strut mount,,,,,looking at the pic it looks like the drive dog has no clearance for shaft wind up witch will put undue stress on the mount losening the screws, when installing the flex shaft make sure that the drive dog has at least 1/8'' clearance between dog and strut bearing...
  14. #139
    Join Date
    Jan 2008
    Frederick, CO
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    anyone with some gps numbers with the stock motor?
  15. #140
    Join Date
    Jul 2009
    Morgan City, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    what are u referring to as strut bearing??
  16. #141
    Join Date
    Jul 2004
    cedar falls, IA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The little brass tube with holes drilled in it...the strut bearing.
  17. #142
    Join Date
    Jan 2008
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    According to what I have read from Grim Racer you can get right around 41mph out of the stock engine using his setup and 50% nitro
  18. #143
    Join Date
    Nov 2005
    MANTECA, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The drive dog has a flat face on the front end and that is where you need the clearance of 1/8 to 3/16''to the rear of the strut where the shaft comes thru,,,,,,,ok?
  19. #144
    Join Date
    Oct 2007
    Grove City, OH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Any low speed needle adjustment to be made of the motor after break in??
  20. #145
    kilr95ss's Avatar
    Join Date
    May 2006
    Clanton, AL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yes, but only after the HSN has been set. You want the LSN set so when you give it a quick squeeze of the trigger, it doesnt bog, you want the rpms to pick up quickly.
    Charles Spradley
  21. #146
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Pipe: Macs Tuned Pipe No. 1328 (trimmed 2 3/8")
    Pressure Fitting: Prather No. 9005
    Flywheel: Shockwave 36 No. PRB2057
    Flex Coupling (collet): Aeromarine No. AEM1732 /OS21 X 187
    Flex Cable: Prather No. 8020 3/16" x 12" Flex Cable (no need for trimming, clean up end)
    Drive Dog: Aeromarine AEM1510 3/16"
    Prop: Octura M445
    Tail Nut: Octura OC6PNMM
    Turn Fin: Aquacraft AQUB9539 (UL-1 Black Fin), need to elongate the bracket holes to fit
    other mods:
    - Engine Mounts (use MVD stock rubber bushings and inserts)
    - Tuned pipe will prohibit the used of the Grim cowl lockes..toss them..they are junk.. fab new locks with hook and O-ring
    - Set rudder back at least 3/4".. I used square aluminum tubing
    - Control box.. (same setup as cowl locks, used picture frame hangers)
    Here ya go:
    After first WOT run without spinning:
    RUDDER EXTENSION:
    COWL LOCKS
    BOX LOCKS
  22. #147
    Join Date
    Jul 2009
    Morgan City, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well does anyone know where to get a replacement rudder tower hobbies says late september but i don't want to wait that long any suggestions mine broke today when it struck something underwater that wasn't visible to the surface nothing else was damaged. this is what i need
    http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXMNX0&P=Z
  23. #148
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I will have some custom machined replacement blades here tomorrow or wensday that just mount in the stock hinge shoot me a PM if interested
    http://www.youtube.com/user/toyotatruckin
    www.aircapitolhobbies.com
  24. #149
    Join Date
    Jul 2009
    Morgan City, LA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I Need the whole thing the metal broke where the rudder connects to the bracket that holds it to the boat
  25. #150
    Join Date
    Aug 2005
    Rochester Hills, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: bmguidry
    *Well does anyone know where to get a replacement rudder tower hobbies says late september but i don't want to wait that long any suggestions mine broke today when it struck something underwater that wasn't visible to the surface nothing else was damaged. this is what i need
    Take a look on ebay. Alot of stores there sell Miss Vegas parts - brand new. Just type in "miss vegas" and scroll down to the stores listings. I saw some there earlier.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
