If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 176 to 200 of 385
  1. #176
    Join Date
    Jan 2008
    Mentone, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: AQUACRAFT'S NEW MISS VEGAS U-18
    Hello, I have some pictures of it posted here in the photo gallery.
  2. #177
    Join Date
    Jan 2008
    Mentone, IN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hello, I have had mine run a consistant 43mph on GPS.
  3. #178
    Join Date
    May 2006
    Lakewood, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: sleepy306
    This boat is such an improvement over the first boat. So far, the only upgrades I have done are grim turn fin and CMDi balanced and sharpened octura y 535. I gps'd the boat (unfortunately no video) with 60% nitro and it ran 43.5 mph. At that speed, the boat gets a bit flighty and a handfull to pilot. I don't know if I should give the strut a degree or 2 of down angle to lower the nose or lower the strut. The strut is set as high as the stock setting allows and has 0 degree angle.
    I can't see how the original miss vegas can compete with this boat stock for stock in an rtr race.
    I stuck 3 oz. of lead on the front of the boat on the inside sponson walls. This seems to help keep the boat running more stable at top speed. I also made a new turn fin bracket from aluminum L material and lowered the Grim Fin. In rough water conditions, this helps keep the right sponson from lifting in a high speed turn.
    JD
  4. #179
    Join Date
    Jan 2007
    Lubbock, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Info needed... I have the duece and I have converted it to the .32 and it runs great. My question is will the stock pipe work with the .32? because the mac pipe is very loud
  5. #180
    Join Date
    Dec 2006
    Del Rio, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Coy, give it a try...I have done some testing with it on a .21 and it works OK.
    Glenn
    Glenn Quarles
    Owner Novarossi of America
  6. #181
    Join Date
    Jan 2007
    Lubbock, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool will try it and get back to you, coimg to Lubbock and time soon?
  7. #182
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: coyv10
    coy, I would definetly not run the stock pipe if you want performance, try a Macs 2340 (or a 2343 which has a 15degree up-angle) header with a 1328 muffled pipe (not as loud). Start by taking a 1/2 inch off each then cut small increments off until you are happy with the performance. You will need to cut out the wood pipe mount (leave 1/8" on hull floor) and trim a bit of hull (where the cowl sits) to accomodate the larger diameter pipe. I have been messing around with the .32 in a deuce for about 5months now and pretty much have her tuned in. Another good idea is to extend your rudder using 3/8" aft and use one of Toyotatruckin's rudders, I tested out the rudder on the .32 and it pretty much solved spin out issues due to prop walk. As mr dunlop said, add some weight to the sponson, I used one and half sticks (4.5oz) to settle the squirrliness
    (torque roll) on straights. After some minor piston sleeve porting I ran a 48.3mph run with other boats in the water, once I was able to get the others out of the pond I hit 50+ then lost the ride due to a loose rudder control arm.
    I happened by this ride, some great work on mods, any suggestions on where to go with her?
  8. #183
    Join Date
    Dec 2007
    Algona, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thats my old hull spent many hours on it oh and dollars
  9. #184
    Join Date
    Sep 2007
    Bremerton, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yea Matt it sucks you got rid of it, but hey at least you got the dumas THAT YOU NEVER USED!!!!!!!!! lol just build that whip ya got and get back to the lake!!! lol.......
  10. #185
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: matt420
    trying to decide what to run in her. Some great work done on modding her, kudos!
  11. #186
    Join Date
    Sep 2007
    Bremerton, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    well it depends on how you wanna run it tod. if ya wanna race it stick an .18 in her! You could even go .21 with the way Matt has her set up. It is a strong hull.
    Jeremy.
  12. #187
    Join Date
    Dec 2007
    Algona, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ya its beefy, trespass check out page 31 look for the thread my outlaw/sport20 vegas and you can see how that hull started
  13. #188
    Join Date
    Feb 2009
    Allentown, PA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    sweet, thanks Matt and Jeremy... I am looking for something great to do for the winter...
  14. #189
    Join Date
    Jan 2009
    , WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    The Deuce is on sale at tower for $249. For tower members you can spend another $1 and get $50 off, so $200 out the door shipped. Good deal
  15. #190
    madmax93's Avatar
    Join Date
    Dec 2006
    halifax, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    yes and it looks like non members can get $20 off too, but it's only untill Jan 31st
    KM baja...Dynamite...HPI Firestorm...Small Bolt...Easy Star...Wild Hawk
  16. #191
    Join Date
    Apr 2010
    Paisley, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
       hope for some help,  first time rc,  ran the second tank of fuel out, refilled the tank, hook up the starter and all that I got was the starter the engine was not turning over.  opened it up and could not find the starter spring nor pin.  talking to teck support, the pin is free floating, does anyone have some ideas of the how or why.  I was really starting to enjoy, for the speed was increasing with only two tanks.  Now I am not sure about keeping the .18 or going to another engine.
  17. #192
    Join Date
    May 2006
    Lakewood, WA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: silverback54
    ** hope for some help,* first time rc,* ran the second tank of fuel out, refilled the tank, hook up the starter and all that I got was the starter the engine was not turning over.* opened it up and could not find the starter spring nor pin.* talking to teck support, the pin is free floating, does anyone have some ideas of the how or why.* I was really starting to enjoy, for the speed was increasing with only two tanks.* Now I am not sure about keeping the .18 or going to another engine.**
    I would suggest you consider using a starting belt and electric starter. The Super Tigre 18 is a solid engine. You need to take the engine apart to remove the spring and pin before running it again. SUPG2052 is the part number for the backplate to replace the gear drive starter when using an electric starter.
    JD
  18. #193
    Join Date
    Oct 2007
    davison, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I need a replacement flex shaft, broke shaft and looking too upgrade, I tried finding a lnk in this forum but there was too many postings to go through, hanks
  19. #194
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    through me on the flexshaft in fact I just tossed up a listing here in the sale section so you can contact me through PM here or use my contacts page
    http://www.aircapitolhobbies.com/Contact.html
    Im easy to find....
    http://www.youtube.com/user/toyotatruckin
  20. #195
    Join Date
    Aug 2010
    Lowell, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well, I just picked up one of these. Hope it was $280 well spent. Just curious, but anyplace to competitively race these in the Mass./NH area?
  21. #196
    amax's Avatar
    Join Date
    Aug 2007
    Crawfordville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    These are whats close to ya
    IMPBA Dist 1
    NAMBA Dist. 11
    Top Speed Hobbies llc. Gotta Need For Speed..
    www.youtube.com/user/topspeedhobbies
  22. #197
    Join Date
    Aug 2010
    Lowell, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Cool, thanks for links.
  23. #198
    Join Date
    Aug 2010
    Lowell, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Well my MVD came in.......couple quick questions: SHould I tear the engine apart make sure there is no debris inside? And what recommendations are in order to make it durable and seaworthy longterm? THanks for helping the noob.
  24. #199
    Join Date
    Apr 2006
    Augusta, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Answer to the cleaning question
    http://www.rcuniverse.com/forum/m_9934109/tm.htm
  25. #200
    Join Date
    Aug 2010
    Lowell, MA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the link, also, what about sealing up and reinforcing the hull? Saw alot of ppl doing that to the original MV, not sure if it needs to be done to the deuce?
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
