Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
K&B 7.5cc outboard bearing life
Reply
Old 09-07-2009, 10:58 PM
fmimages
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default K&B 7.5cc outboard bearing life
Since I have been playing with this particular engine and tunnel boat I have had nothing but problems, like fix it. The motor is an old one 8701 as well as the boat, but I thought I could run it and have some fun. I replaced the pto bearings last year and the time before I have replaced the front and rear bearings. I don't get a chance to run it much so I haven't gone through too much fuel. I'm learning to tune the boat slowly and experience all the problems. Now I'm fed up. I just got it running and then I heard the telltale sounds of a bad bearing. Is this normal for such little use. I use after run oil and always look it over each run. My receiver batteries and glow plug starter work fine after twenty years of recharging. I've learned the difference between stale fuel and fresh nitro fuel since I go a long time between runs. I'm just getting tired of having to order another bearing. I'll order a full set of bearings this time and then see which one needs replacing. Is this normal for these engines?
fmimages is offline
Old 09-08-2009, 07:45 AM
f16man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: K&B 7.5cc outboard bearing life
Are you flushing the engine out real good? Pull glow plug and open carb all the way and spray some carb cleaner in glow plug hole and carb ,don't be stingy, spin engine with starter and repeat, now you have the fuel washed out and the after run oil will protect the bearings , I use transmission fluid for afterrun oil.......
f16man is offline
Old 09-08-2009, 07:57 AM
mike walker
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: f16man
Very good advise I was just oiling my engines and found that I was getting little specks of rust that hurt the piston and bearings I now do a better job like stated above
mike walker is offline
Old 09-08-2009, 02:51 PM
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
never lost a bearing since i started running that engine in the early nintys ran in salt and fresh watter but a would always flush my engine with WD 40 remove the plug open carb fill engine spin the engine over with starter add more wd 40 wipe engine down reinstal plug
rcguy1411 is offline
Old 09-08-2009, 09:40 PM
fmimages
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the advise. I was doing the WD40 flush & etc. but when I was having problems and only got a minute or two of a run I got lazy and put it away. I can't tear the engine apart till I get some money but that could be why a bearing went bad again in such a short run time.
fmimages is offline
Old 09-09-2009, 07:49 AM
f16man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ya these boats are a lot of work to keep em up but worth it.....................
f16man is offline
Old 09-12-2009, 01:19 AM
fmimages
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I tried to run today. Have sanded and rebalanced the props due to prop damage with a rock (my error). I have taken the engine apart and can't find anything wrong with any of the bearings. I greased the flex shaft with white lithium grease.I couldn't get past the cavitation and bearing (shrill) noise problems. I have Octura X447 and X450 and couldn't get more than an eigth of a tank use. This is getting to be too much for so little stick time. My glow plug element looked white/grey so I'm stumped. I have noise that sounds like bearing sounds but all the bearings I examined felt okay.
fmimages is offline
Old 09-12-2009, 06:43 AM
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
since you have had the flywheel off could the noise be from contact between it and the case ? or it mighy be in the pto (where the cable conects to the powerhead ) try removing the flex cable start engine if the noise is still there you know its in the power head to fix the cavatation try lowering the engine 1/8 inch at a time
Old 09-12-2009, 06:48 AM
rcguy1411
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what shape is the teflon liner in for the flex shaft if worn noise could be comming fron there
Old 09-12-2009, 11:58 PM
fmimages
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the help. I'm going to need to be more careful with my troubleshooting. I already took the flex cable out to troubleshoot. The pto bearings are new and feel smooth. The flex cable and teflon housing are new. I've greased the flex shaft lubed it with gear oil but the noise persists in a few minutes of running. I'll lower the prop by an eigth of an inch since these runs are after a new paint job and I am a greeenhorn at adjusting things. I have a few more hobbies so I have to wait a few days. It just seems perplexing since the bearings appear good as well as the other components.
fmimages is offline
Old 02-06-2010, 02:01 PM
dyna_rider98
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: fmimages
fmimages
I saw a picture that you posted of your boat I also watched the you tube video. What brand is the boat? What % fuel are you running? Happy boating Fred
dyna_rider98 is offline
Old 02-06-2010, 04:55 PM
Dan S
Dan S's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what % oil do you have in your fuel?
Dan.
Dan S is offline
Old 02-10-2010, 08:06 PM
jetpack
jetpack's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An inner race slipping on the crankshaft could be causing the noise, but usually when that happens it will drop RPM's when it does it. It usually won't give you much time if that is the case to change the crank before it finally galls up enough to weld itself together.
The top bearing seems to take the most wear on my 3.5SS.
jetpack is offline
Old 02-12-2010, 12:53 AM
jmy2u
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can also get that sound from your propshaft assembly. It should be lubed everytimme you run and also flushed after running. It can also sause some cavitation if it is worn to badly.
jmy2u is offline
Reply
Display Modes
