how do i clean up a nitro fuel leak
FL
i picked some boats and they have nitro fuel leaked in them the one is a wood hull it has taken the paint off the bottom
the other one is glass it also has the paint coming off bottom the wood hull i have sand it down because i was going to paint is but cant pant over the fuel so i am trying to it a clean so i can pant they both need to be re panted bottom and a 3rd one i just want it get cleaned before it gets to the pant thank you for any help you can give i can post pics at a latter time
RE: how do i clean up a nitro fuel leak
I am going to lose my tunnle boat after this summer due to a fuel leak my fault for leaving fuel in it. but the best I have found is to use a good dish soap wash well and let dry for a few days at least
FL
here are some pics of the wood hull still have some sanding do don't have a pic of the other one its in the car right now
FL
cool its not soft at all . i cleaned it with some alcohol seem to be drying up nice .what do i need to seal it with epoxy ??
thank you for the help
On a repair I use 30 min. epoxy and thin it with a little alcohol just thin enough to bush on. sounds like you goter made youll be in the water soon
FL
its going to sometime before its back running it is all a part got 2 or 3 i am working right now still have to clean the leak in the nitro glass hull here a pic of my motor still need some cleaning need to find a turn fin for it too
OH
use some simple green or purple power..Those stuff cleans up the fuel great!! What it if that nitro leaks on that glass and sitting on it,it will puke up that glass work too..and you may have to reglass that area because the nitro soften the glass work.
FL
here are some pics of the glass hull its not soft just the pant is lifting off my other glass hull i clean it and its fine i end up buying used stuff all the time going to pick up 3 more on sat and 5 motor's but only keep one and 3 of the motors been wanting a hydro lol the rest will be for sale
ON, CANADA
let me guess its a shockwave wuth a dynamite they are natorious for fuel leaks if im right i picked up a thundercat a few years back they have a reputation for fuel leaks change the fuel tank before you put fuel in it again DONT use a stock one they all have problems with the nipple on the bottom
FL
its a formula fast tech i have a shock wave never and had any leaks i got this one used they had rip the fuel line off bottom of the tank
and left fuel in the tank i don't leave the fuel tanks in my boast when i am not running them
ON, CANADA
ouch ive been running a .32 for a couple years with no problems have about 7 to 10 gallons of fuel through it still running strong ive had a couple proboat and they all had fuel leaks and it all came from bad fuel tanks
