If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Page 132 of 165 FirstFirst ... 3282122130131132133134142 ... LastLast
Results 3,276 to 3,300 of 4101
  1. #3276
    advanced builder's Avatar
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Central NEW YORK boaters
    Roger was the first to reply as to the hull. Rick bd has the decals coming. If you really want it you can wheel & deal with Roger. 1/8 scale hydro was big before gas. the .67 was king. fuel cost and plug cost made the hull obsolete. And one hit and she's in the shop for months.
    Stoney Pond Model Boat Club, Canandaigua, NY
    International racer
    http://neilsrcsite.shutterfly.com/
  2. #3277
    Join Date
    Sep 2003
    rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Neil please put me down for a case of 40% fuel, thank you for arranging the fuel order for us.
  3. #3278
    Join Date
    Sep 2003
    rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Craig, I would like to attend the meeting on 1/6 if there's enough room. I have run many RC events and I think could help. Let me know.
  4. #3279
    Join Date
    Feb 2008
    Canandaigua, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: lynnb
    Sure, sounds good.
    Craig Mapstone, IMPBA #20305S, Stony Pond Model Boat Club
    2012 D1 20 Hydro Champion
  5. #3280
    Join Date
    Sep 2003
    rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Roger and Rick, I to am interested in Neil's 1/8 scale hydro. After seeing bdog1's run I am hooked on that style boat, I have a line on an engine as well. Being new to the boating hobby that style boat really catches my interest. Thanks
  6. #3281
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Good day EH? I have a couple questions for the "PROS".. should the rudder and strut leading edge be sharpened like the turn fin??? also....Is there supposed to be a gasket between exh. man. and header for pipe?? its water cooled zippkit header-pipe setup, i only got one gasket that i assume is for the carb to intake man..... the 2 o-rings i figured out I think.. bigger dia. one outside pipe in coupler and smaller dia. one between pipe flange and water cooled exh. header...??? but a straight mount for the header to exhaust manifold... no gasket??? not sure.I may have gotten a rt. side rudder because the horn for pushrod is on the outside of rudder,I made the pushrod go between pipe outlet and rudder, it seems to work,is it ok?? next, blue threadlock on all metal to metal bolts etc.for final assy.?? I assume not on plastic carb intake manifold bolts...? things are a bit different on planes and i just wanted to check these things out.Had everythind assembled today(fun putting engine with carb. and exhaust flange assy on in boat) then back apart for sealing holes i drilled and radio box plus glued box in place.. the plans are not kidding when it says throttle linkage in a "tight spot"...... next i get to put it all back together!!! yippie any hints or info on this stuff appreciated.
    Rick
    ParshallWoodworks If you can dream it I can build it
    Stony Pond Model Boat Club,Cdga.NY
    Sky Chiefs flying club Cdga.NY
    Rick
  7. #3282
    Join Date
    Feb 2002
    St. Paul, Indiana
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rick,
    Yes, use a gasket between the water cooled flange and engine.
    O-ring order does not matter. Use oil to lube.
    To get the rudder arm on the other side, flip it over and drill the small hole larger.
    I don't use any loctite. Everything uses either lock nuts or lock washers...
    Joe
    -Zippkits-
    People make this a great hobby!
  8. #3283
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Joe Petro
    Rick,
    Joe
    Thanks Joe... did i put the gasket in wrong place or lose one?? my afterthought was i might not need one on plastic carb mount...??and with rudder do i use same breakaway brass bolt or will that have to be bigger too?? plus the kit comes with a pipe mount and hardware pkg has a base... looks nicer, just use that and bolt to bulkhead?? thanks
    Rick
    Rick
  9. #3284
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: lynnb
    You got it . I case of 40 %
    International racer
  10. #3285
    Join Date
    Feb 2002
    St. Paul, Indiana
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: parshallboatworks
    ORIGINAL: Joe Petro
    Rick,
    Joe
    Rick
    If you didn't get an exhaust gasket, I will send you one.
    For the Bullitt, use the 1/4 inch ply pipe mount and part of the aluminum pipe mount set like we show in the instructions.
    Also, use the aluminum spacer that we supply with the pipe mount. The rubber one will overheat inside the boat...
    Use a 6-32 bolt in place of the smaller one in the rudder. Use nylon, aluminum or brass if you want a shear bolt.
    Joe
    -Zippkits-
  11. #3286
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: lynnb
    You can still get a kit and build one. Dumas made the Atlas Van Lines Miller America ,Circus Circus ,like so http://www.dumasproducts.com/product...roducts_id=249
    Or http://www.blazermarine.com/index.ph...uct_detail&p=3
    or http://www.ml-boatworks.com/Page.asp...-boatworks.com
    I may have misses one or 2 sites. Dumas has the worst plywood to work with. The blaze hull has many pieces the other I know nothing about.
    The Price of the Dumas Hull jumped right out at me,the hull cost $225 long ago.
    International racer
  12. #3287
    Join Date
    Feb 2002
    St. Paul, Indiana
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    We are gonna have to raise our prices!
    A Thunderboat wood kit for $210 plus $90 for cowling plus $50 for turn fin= $350.00
    A gas scale frame kit for $160 plus the sheeting (make your own) plus cowling plus fin= $hundreds more...
    Our most expensive Gas Thunderboat kit is $199 and includes a cowling, turn fin and all CNC cut wood...
    Wow!
    Joe
    -Zippkits-
  13. #3288
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Joe Petro
    ORIGINAL: Joe Petro
    Rick,
    Joe
    Rick
    Joe
    Joe,
    didnt see a second gasket. I had the pipe and fancy tailpipe extension and rear exit all set up for a dry run,and radio set up before i sealed radio box and glued in... Just down to finishing touches now!! I will switch around rudder and drill bigger hole as it will probably work better on inside rather than outside.. just a small hole,easy to patch.. I am guessing the long 5/16" piece will be shipped (or was) shipped with the kits that are on thier way?? Or wasnt that part of the combo? this is the one for drive line.
    I "borrowed the one out of propcircles A BOX kit that i am building for him....ssssshhhh LOL... if not included let me know and i will order one.Thanks again,
    Rick
    Rick
  14. #3289
    Join Date
    Dec 2011
    Walworth, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Joe Petro
    Joe
    Answered my question before I asked it... I was working on this onFriday night. I didn't think about the rubber getting hot, good point. I hate to not use the foot portion of the pipe mount, it's a trick bit of billet!
    TC
  15. #3290
    Join Date
    Dec 2011
    Walworth, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Yeah I told you these things are like Rubik's Cubes! Wait until you get to take the pipe off/on with the motor still in the boat... we were looking at this over the weekend, might not even be possible as the whole exhaust is under the deck on this hull...
    TC
  16. #3291
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: klinker19
    TC
    actually the exhaust flange sileds into pipe enough to sneak it in-out with engine in place!! sure makes it hard to reach motor mounts and throttle linkage is buried... I am about ready to run!!!hows yours going K-19???
    P.S. if you cut the alumn. tailpipe piece the right length it will slip in and out with engine and header in hull... took some experimenting but it will... had the engine in and out about a dozen times till i got it right..luckily the tailpiece fits nicely over the pipe and you gain the whole length of the pipe end to slide...
    Rick
    Rick
  17. #3292
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Getting there... have to finish sharpening turn fin... and install exh. gasket... plus reciever and battery,oh and a prop might help!
    oops.. was kind of hoping for pics.
    Rick
  18. #3293
    engineman351's Avatar
    Join Date
    Sep 2008
    Rochester, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rick...the build looks great! Is that a carbon rod for the rudder...or just a Sullivan tube and some 4-40 rod?? Roger
  19. #3294
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: engineman351
    Its 2 pieces of 4/40 pushrod and a carbon fiber tube Roger..thanks for the compliment!!!
    Rick
    Rick
  20. #3295
    Join Date
    Feb 2008
    Canandaigua, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rick, looks fantastic!
    Sounds like Neil has a hot item, the 1/8 scale, I say the highest bidder gets it.
    I've been building a sound barrier on the corner closest to the nearest neigbhor with extra dirt. Yes, we have a lot of extra dirt. It should work pretty good. The Kubata with loader was money well spent. I'm almost to 150 hours. Mostly work on the pond, but also snow plowing and hauling firewood.
  21. #3296
    Join Date
    Feb 2006
    Baldwinsville, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    looks like wet weather. Then winter coming in, so you better hurry. REALLY NICE HULL Rick
    International racer
  22. #3297
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Blackout
    Thanks craig!! like the sound barrier too.. LOL.. I will start the bidding for 1/8 scale hydro at 5.00$
    Craig you still have any qts. of 50% laying around?? setting both our boys with boats for Christmas and would like to giv em fuel too...Rick
    Rick
  23. #3298
    Join Date
    Feb 2002
    St. Paul, Indiana
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Rick that Bullitt is AWESOME! Holy!
    Really nice job!
    You can cut those bulkhead tops right off...
    Joe
    -Zippkits-
  24. #3299
    Join Date
    Feb 2008
    Canandaigua, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Blackout
    Craig you still have any qts. of 50% laying around?? setting both our boys with boats for Christmas and would like to giv em fuel too[img][/img]...Rick
    Yup, I have plenty of 50% in quarts. Let me know when you will be in the area and you can pick them up.
  25. #3300
    Join Date
    Dec 2011
    Bloomfield, NY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: Joe Petro
    Really nice job!
    Joe
    Thanks Joe... you like to see your stuff getting the attention it deserves?? I left the bulkhead tops on cause i like the extra suport it gives...She is just about ready!!! going to be in water soon.. then i can post VIDEO rather than pics...
    Thanks Neil, it is coming out nice... I have another boat on bench,and 3 more on way!!!
    Rick
    Rick
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
