Thanks Dick
ORIGINAL: Blackout
what do you think??? anyone say yes or no??? thanks, rick p.
Can you notch and then reinforce the tub?
Or post a WTB for a .21 K&B header, but you'll need a new exhaust throttle or a carb too.
You could also look into soldering your own header using copper plumbing tubing and brass plate from the hobby store. You might be able to use the existing exhaust throttle doing this. I did this with my O.S. outboard on the tunnel, but I used 90 degree pieces. Getting a .21 pipe is the easy part.
ORIGINAL: rickyak55
hey Craig... the K&B motormounts are much smaller than the solinger mounts... also the stock muffler will not fit in hull.. too wide.. dont know what to do..[img][/img]... buy new engine? put pipe on old K&B..? a little frusterated.. nothing seems to come together,wit what i have... .67 engine.. .45 engine... 3 .21 boats and the one engine i have wont fit complete boat i have... the wood rigger i showed you will fit K&B.. maby i should just get that going..?but then i need a flex shaft etc. etc.... urrg...
