Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
Reload this Page >
tc31 needs new engine suggestions for drop in replacement.
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
View Poll Results: A poll
new dyn. .32
14.29%
other engine
42.86%
new boat and scrap tc31
42.86%
Voters: 7. You may not vote on this poll
Old 07-23-2010, 08:24 PM
loosenut510
Default tc31 needs new engine suggestions for drop in replacement.
my tc 31's dynamite .32 just went south. i think something internal is bent it is very hard to turn. motor is out of boat soon to be dismantled to fnd cause of failure. main complaint with boat before engine failure was EXCESSIVE cavitation i could not stop. lowered strut WAY DOWN in water and still cavitated. thinking of buying new boat. maybe shockwave 36???? suggestions please and maybe some pointers on what could have caused engine failure
EDIT:: problem found. main crank bearing seized.
Old 07-24-2010, 12:15 AM
Ron Olson
Ron Olson's Avatar
Default RE: tc31 needs new engine suggestions for drop in replacement.
There are many tihngs that could have caused your cavitation problems. The boat will take off and not suck air if you give it a toss when launching it, not just plopping it in the water. You could have cooked the motor by not running it at a fast enough speed to keep water flowing through the head, running it out of the water too long, blocked flow, cracked lines, lousy fuel, the carb too lean and the list goes on.
I've already mentioned a bad-ass engine several times before that could make the boat faster than snot but nobody has tried it yet that I know of, a Nova Rossi .28. This little puppy in a 'riiger made the first 100+MPH pass at Thread Lake in Flint, MI last year taking the "C" hydro record. Now it won't do that in your Cat but it shows how wicked that little mill is.
Old 07-24-2010, 10:22 AM
amax
amax's Avatar
Are you running the Stock Prop, and has it been Sharpened and Balanced?
If it has not been S&B that Is the cause of your cavitation. If you were excesivly revving the enginw While it was cavitating, that is Most Likely what happened to the bearing. You probably have a bent rod also.
What engine temps were you running the day it happened?
Personally I would Rebuild what you have and Tweak it while your in there.
Old 07-24-2010, 06:58 PM
res3567
Hey Ron....you got a link?
ORIGINAL: Ron Olson
Old 07-24-2010, 07:45 PM
Ron Olson
Ron Olson's Avatar
Yes, www.novarossi.us . It might not be on the site but contact Glenn Quarles for more info on it.
Old 07-24-2010, 08:47 PM
res3567
Dude...they are located here in TX. outside of San Antonio...about a few hours dirive....I will definately contact him....Thanks Ron!
Old 07-24-2010, 08:58 PM
Ron Olson
Ron Olson's Avatar
No problem. He just moved to Del Rio recently. Contacting him on the weekends is usually the best time as he travels a lot during the week. I know that he sells a lot of items that aren't on the site so he may let you know what else he has available that you might need to make the engine swap easier.
Old 07-24-2010, 09:46 PM
loosenut510
i have dremeled the strut so i can drop the prop even lower in the water. i was running a octurra x440/3 prop. i just dont know what to do. i thought of getting a new engine but i ialso thought of buying a shockwave 36. i really want a deep vee hull. what about the aquacraft 27
Old 07-24-2010, 09:48 PM
loosenut510
whats the phone number for novarossi???
Old 07-25-2010, 08:04 AM
Ron Olson
Ron Olson's Avatar
(210) 392-2271 It's under "Contact Us" on the site.
I've only talked to Glenn once. It seems like we've got a mutual acquaintance for as far as we are apart, BASS pro fisherman Kevin VanDam so we talked fishing more than anything.
Old 07-25-2010, 08:55 AM
amax
amax's Avatar
The 440\3 is not enough prop for the TC31 no wonder you smoked it, a sharpened, balanced, and Polished M445 will work Much Better.
New bearings for that thing are Cheap, stock from DYN are about $10ea, Boca has em for that engine starting at $28 and going up to $69 for their ceramics. I can get Real Good bearings for it also for a better price than Boca.
Old 07-25-2010, 09:55 AM
Ron Olson
Ron Olson's Avatar
Yes, you're over-revving the motor using the X-440/3. WW and I hit upon the X-445 kind of by accident. We were digging through my box of props and he wanted to try that one out. We never said that it is the best prop for the boat, just the best one that I had handy but so far a lot of people have since gotten one and have loved it! A Prather 220 came in a very good second place.
Old 07-25-2010, 02:37 PM
Serpents Den
another one that would be good to try, is the Rossi T35 marine
Old 07-25-2010, 04:37 PM
amax
amax's Avatar
Back when I was cutting props for "Him" we do not speak of,,,, the M445 was the Go To prop for both the stock TC31 and the SW36, for high nitro users and mod engines the M545 and some of the better tuners could get one to turn the X646.
Old 07-26-2010, 05:14 PM
loosenut510
how do i make it stop cavitating?? i have dremeled the strut so i can lower it more and it still cavitated even more so when i made a turn. it would just stop dead in the water and spin
Old 07-26-2010, 06:44 PM
amax
amax's Avatar
If your talking about the 440\3 you probably wont stop it from "Slipping", it's To Small for the Torque\Weight your dealing with. You need a Bigger Prop like the M445, and it Must be sharpened and balanced.
Old 07-26-2010, 07:46 PM
loosenut510
what about the aquacraft 27?? is it any good? the .18 motor it has has a little more power than the .32 dynamite motor. any experience with it???
Old 07-26-2010, 07:58 PM
Ron Olson
Ron Olson's Avatar
Just a little. See the thread that I authored on it.
Old 07-26-2010, 08:48 PM
res3567
Just a little....... LOL! Ron...must you be so humble?
ORIGINAL: Ron Olson
Old 07-27-2010, 06:41 AM
amax
amax's Avatar
Well don't put to much time into reading engine Specs, Most are all Hype. The TC will handle rougher pond conditions, the SV27 will maneuver better. Personally I've never been real impressed with the quality of the aquacraft hulls in general, but all RTR Boats have their own list of issues. Honestly I wouldn't trash a boat just because the engine blew, if I was getting a RTR mono I would go more for the Shockwave 36. Size Does Matter.
Old 07-27-2010, 08:05 AM
Ron Olson
Ron Olson's Avatar
It sounds like a lousy 2-1/2mm extra diameter on each blade but it's also multiplied by a factor of 1.4 or more depending on the prop so the larger the prop, the more pitch you're getting.
