GO ENGINES
#127
IL
RE: GO ENGINES
I agree. I bought a .18 Go from Amax. I have around 30 min just in bench break in and plan on another 30 min of break in on the water befor I even start to race it. The last engine I had I put probably 5 gallons through it before I sold it and it still ran just fine.
As far as the modified Go from Amax, it's about as fast as any $400 itilian engine. But a well setup boat is just as important if not MORE so.
My 2cents.
My 2cents.
#128
FL
RE: GO ENGINES
ORIGINAL: FreeS7yl3r
Hello,
im interested to buy a Go .18 engine.I see it's powerfull and running good , but im also interested in the fuel consumption.Also how much life can i expect from this engine when running 10-20% fuel ?How fast do bearings wear ?
I want to know , because when i first bought a CMB , they told me that it need 1.5l fuel for 30minutes and bearing change every 1 hour(and the price for a set of bearings was around 50$)
Hello,
The bearings are ABEC 5, which are some of the best I've Seen in a .18 engine,, If your just Pond Hoping on the neighborhood pond on low nitro, you Tune the engine Right All the time and Flush the engine with WD-40 and use After Run Oil(ARO) "EVERYTIME You Leave The Pond" they will last the life of the piston and sleeve.
I don't really measure fuel consumption in Minutes, I measure in "Laps" around the track. With a Fully Modified Engine (I Don't run Stock) I get about 12 to 15 laps "Wide Open" on 5oz of fuel.
