old servos/ new radios
all these boats that ive had dry docked have really nice servos ( high torque,high speed) but theyre all at least 10 yrs old. my question is will these servos work with 2.4 ghz radios
thanx |
RE: old servos/ new radios
it should work unless it has different plug or wires, then it needs modification.
Yes they should work just fine I use Analog(old Servos) in all my boats with a Spektrum 2.4ghz system No Problem. Some of the other systemes will operate them but you may have to Failsafe settings each time you power the system up.
Change the plugs if needed
