Great Planes P-51 Mustang Sport Scale
My Feedback: (7)
NC
RE: Great Planes P-51 Mustang Sport Scale
Your assessment is basically correct. It is a sport plane dressed like a P51. Has enough scale realism to tell what it is but not enough to make it a "warbird". I had one a couple of years ago with an OS 61FX. It flew great.
Brian
Brian
My Feedback: (34)
Just about done with mine....terrible covering - keep wrinkling and when heated just makes a big bubble of hot air....it takes many pin *****s to get all the air out. Plane balanced right on the money w/ OS.46AX! Hope to test fly this weekend.
ME
Besides scale looks, I know that the Hangar 9 P-51 Mustang 40 Sport is designed to fly somewhat like a "sport" airplane but does it have more "warbird" qualities, if any, from the Great Planes Sport Mustang or are the two Mustangs basically the same ?
Do they both share that Mustang look from the outside but are just a sport airplane on the inside ?
ME
Besides the scale looks, I'm wondering if the H9 40 Mustang handles more like a "warbird" or has that "warbird" feel from the GP 40 Mustang? Or is the H9 40 Mustang another sport airplane in the P-51 disguise like that of the GP model?
My Feedback: (34)
I personally feel the H9 flys like a Mustang should, but perhaps it is the fact that the gear is up and I can push 104 MPH with it. It handles some maneuvers like a sport model (like spins) and on low rates can do some excellent victory rolls (very warbird like). The GP 'Tang on the other hand, has a smaller engine, and flies rock solid also - but watch spins - mine will take 2-3 full rotations to stop spinning - very full scale like!
Perhaps it is in the hands of the pilot, but the pluses of the H9 outscore the GP by a little in the flying department. In static both are stand - off or WAY-OFF if you are a scale fan.
Landings go to the H9 due to slower smooth landing attributes (flaps while not needed, are the way to go!).
hello, I will buy this plane, I would like to know if it really flies well with a .46 or need a bigger engine?
Thank.
Fermin Quezada
Dominican Republic.
Thank.
Fermin Quezada
Dominican Republic.
P51 Mustang sport Scale is 46 Nitro plane,use the OS 46 engine.
I have one P51 Mustang 60 Nitro plane,if you need 60 class Nitro P51,
I sell P51 Mustang 60.
Wing span: 65.5in / 1664mm Wing area: 745 sq in / 48.1 sq dm
Flying weight: 7.8lb / 3540g Fuselage length: 55.8 / 1420 mm
Engine Required: 2c 0.61-0.75 cu in 4c 0.91 cu in Radio Required: 5 channels,6 servo
Hello tailskid
I wonder if not given you any problems with the engine reversed, I have an asp. S52aII mounted on mine and after the first flight to the air, not if the engine is not really the position.
any help would be appreciated
Greetings.
Greetings.
