Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Starting inverted engine?
Reply
Old 07-04-2012, 06:37 AM
pjwilletts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Starting inverted engine?
I have a pumped 120 glow engine mounted inverted that floods and isvery difficult to start..any suggestions?
pjwilletts is offline
Old 07-04-2012, 09:03 AM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Starting inverted engine?
I'm not an expert on pumped engines, but on regular glow engines, I usually don't have any problems.
The first question is: What adjustments have you made already? Can you go back to square 1 and start again?
The next question/suggestion was whether you ever had this tuned to run perfectly in the upright position before you mounted it, especially in the idle region.
These are just for starters. Just my $.02
Bob
N1EDM is offline
Old 07-04-2012, 08:55 PM
pjwilletts
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the engine ran fine upright and side wayse...i think the problem is that too much fuel is being fed into the cylinderthan the plug can burn off..
Old 07-05-2012, 05:02 AM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you had the engine upright, how was the idle. was it lean enough so that you wouldn't pool fuel into the cylinder? How was the transition.
As for adjusting the pump (if needed) I can't talk to that. I had just noticed that when I used an inverted glow, if it wasn't set up right it would usually richen and die on me.
Also, how was the humidity when you were doing the tests? Out here we've had high humidity recently and it really affects the tuning of our engines.
Bob
N1EDM is offline
Old 07-08-2012, 09:24 PM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It may help if you use a glow plug with an idle bar. Second, don't choke and turn the engine over before trying to start it. Leave the engine dry and just hit it with the starter.
countilaw is offline
Old 07-08-2012, 10:21 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've had good experience of starting the engine upside down on a stand (with an inverted engine). Simple & efficient 100%
vasek is online now
Old 07-09-2012, 09:43 AM
Rv7garage
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When an engine is mounted inverted, the height of the carb in relation to the fuel tank can change. If your carb is lower when the engine is mounted inverted, you can (will) get siphoning. You may have to change your tank height to make this work properly.
Rv7garage is offline
Old 07-09-2012, 11:02 PM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
as RV 7 garage Says tank location is important. The tank centerline should be about 1/4 inch below the carbs spray bar....If you are to far above you will get siphoning and flooding...This is espially important in inverted engins because fuel runs to the lowest spot and floods the glow plug.... You need to be really carefull here too because you can easily hydrolic lock your motor and bend the rod when trying to start it...
bikerbc is offline
Old 08-13-2012, 01:21 PM
ddd
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check your pump for a valve leak, you should not be siphoning past the pump.
ddd is offline
Old 08-13-2012, 06:59 PM
speedracerntrixie
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ddd
Agreed, a pump should not be flowing fuel until it gets pulses from crankcase.
speedracerntrixie is offline
Reply
Display Modes
