Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Stuffing a DLE 20 into a Hobbistar 60
Reply
Old 11-23-2013, 07:09 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Stuffing a DLE 20 into a Hobbistar 60
The time has come for my trusty Hobbsitar 60 trainer to say goodbye to glow and hello to gas. A little history:
Bought it as a shiny new RTF in the spring of 2011 for training at my club's flight school. Here it is all fresh, new and ready.
It was a great trainer and served me well. In the spring of 2012 I stuffed it in a tree and over the winter of 2012/2013 I rebuilt the badly damaged wing and converted it to a tail dragger. It last flew, on skis, early in 2013.
The last flight was a great success, but I decided I wouldn't fly it again until the slimer was gone and a gasser had taken its place. In the early summer of 2013 I bought an RCGF 32 to put in my Pulse 125, from which the DLE 20 would come for the Hobbistar.
I started the transformation this summer by removing the OS 65 LA engine and selling it along with all of my glow-related equipment. The installation of the RCGF 32 into the Pulse 125 is almost complete, and it's time to get started on this project.
grosbeak is offline
Old 11-23-2013, 07:16 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As shown in the previous photos, the OS 65 LA lived between two cowl cheeks. The DLE wouldn't fit so after a thorough cleaning of the entire airplane, they were the first things to go.
There's no way I could install the ignition components and fuel system through the center of the fuselage, so the next step was to expose the front compartment by removing the upper panel.
grosbeak is offline
Old 11-23-2013, 07:22 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On the inside of the firewall are six blind nuts - four for the motor mounts and two for the long-gone nose gear mount. They were removed by threading in a 4mm bolt...
... and tapping on it until the blind nut came loose. They weren't glued in place so they came quietly.
Next step was to drill out all of the holes (8 x 1/4" and 1 x 3/8"), clamp on a back plate...
... And tap in some dowels.
grosbeak is offline
Old 11-23-2013, 07:28 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While I was taking a look inside the front compartment I noticed that the starboard tri-stock brace had separated from the firewall. That had to come out.
I soon discovered that the starboard fuselage skin had separated from the firewall too.
That got some glue...
...and got clamped up. I will definitely be pinning this firewall.
grosbeak is offline
Old 11-23-2013, 07:35 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While the glue was curing I held the DLE 20 up to the firewall. Ruh roh... that mount is too wide, and if they make a narrower one I haven't seen it.
Time to think outside the box.
I'll be designing and building a custom cowl so accommodating this configuration will be no problem.
grosbeak is offline
Old 11-24-2013, 06:04 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Replaced the separated tri-stock - Here it is glued and braced to cure.
Marking the holes to pin the firewall.
The pins are bamboo skewers. I cut them to length, then chuck them in the drill and run them against some sandpaper to taper an end.
Presto.
grosbeak is offline
Old 11-24-2013, 06:08 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A little glue.
Three in and ready to tap 'em home.
When the glue cures, out comes the flush cut saw.
All done.
grosbeak is offline
Old 11-24-2013, 06:11 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next step - a mounting block for the top forward access hatch. Here are two shims and two mounting blocks.
Shims are glued and clamped.
Marking the hatch for the mounting holes.
Holes drilled.
grosbeak is offline
Old 11-24-2013, 06:14 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using #4 x 1/2" button head screws that came with the RTL Fastener Master Builder Assortment.
Mounting blocks glued and clamped.
Mounting blocks cured and ready.
grosbeak is offline
Old 11-24-2013, 06:19 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hatch cover taped in place.
Using a transfer punch to mark the drilling point.
Using a hand drill for control and a brad point bit for a nice clean hole.
Threading the screw holes. I drizzled some CA into them afterwards.
grosbeak is offline
Old 11-24-2013, 06:24 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hatch cover test fit.
grosbeak is offline
Old 11-25-2013, 09:29 AM
raptureboy
raptureboy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't forget to remove the wings,since the DLE is so powerful this will now become a rocket and the wings will not be needed. Can't wait to see the flight vid's.
raptureboy is offline
Old 11-25-2013, 09:38 AM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Duly noted.
grosbeak is offline
Old 11-25-2013, 01:12 PM
hookedonrc
hookedonrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And when you get ready to stuff a G26 into an Avistar I want to watch.
Lookin' good grosbeak
hookedonrc is offline
Old 11-25-2013, 03:38 PM
GerKonig
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would put the servos in the tail section, and you might want to build a hatch in the tail to offset the weight of the gas power plant. Of course the landing gear will have to be beefed up a lot because the total weight once finished and balanced will be much more than originally. Not to mention the weight added while reinforcing the nose.
Good luck with the project! One thing is for sure, it will fly very different...
Gerry
GerKonig is offline
Old 11-25-2013, 05:46 PM
pedro w rdz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cant
wait to see that one fly
pedro w rdz is offline
Old 11-25-2013, 05:55 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks hookedonrc. I don't have an Avistar or a G26 but you never know what might happen.
Gerry
Thanks for the tips, Gerry. I'll keep that in mind. Incidentally, the gear is not stock - this used to have tricycle undercarriage before I converted it to a tail dragger. The main gear on it now is much stronger than the original.
Quote:
Originally Posted by pedro w rdz View Post
Cant
You and me both!
grosbeak is offline
Old 11-25-2013, 05:56 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This evening I turned my attention to mounting the engine. I started by marking the centre lines on the firewall.
Then I marked the thrust line of the DLE 20 on the motor mount.
Seems to me that the thrust line should be centred laterally on the firewall. With that in mind, here's where the engine will go, at least from a side-to-side perspective.
The current port side mounting bolt holes are too close to the side of the fuselage, so I plan to drill new ones.
grosbeak is offline
Old 11-28-2013, 08:50 AM
rglgatortail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its been a couple of days where are you at on your conversion?
rglgatortail is offline
Old 11-28-2013, 11:17 AM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I set it aside while I waited for feedback on a thrust angle question.
In the meantime I've been working on the conversion to dual aileron servos.
grosbeak is offline
Old 11-28-2013, 04:54 PM
rglgatortail
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you are going to use a large size 4 stroke then you will have something to worry about, that dle 20 will want to spin a 15-6 prop so I think you will have prop clearance more than anything else. If anything just leave the motor in the center of the fire wall centered on x and y and just use different length standoffs to get about I think 3 degrees will be about enough so the planes left side will be about quarter inch longer than the planes right side.
Old 11-28-2013, 05:28 PM
Propworn
Propworn's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HMMM that DL and the added re-enforcing weighs just about twice what the OS weighs and you've mounted it in about the same location as the OS. How do you intend to balance the plane with this extra nose weight? Nose to tail ratio from the CofG would be about 4:1. OS is about 18 oz divided by 4 is 4.5 oz minimum as far back in the tail to balance. Think about doubling the size of your elevator and rudder and using less deflection to do the job. You may need the extra surface area to effectively move the extra mass of the engine about the axis of the plane especially at lower air speeds. That landing gear may prove to be inadequate for anything but a smooth landing. If it flexes to much it might be hard on prop tips. We have pressed out the axles on the Dubro bolt on axles then fed the same diameter piano wire straight through both sides, very strong but it doesn't flex at all. You can see the result of a similar gear on my heavy lifter where the plane weights 7 lbs and is carrying close to 23 lbs in lead. On landing it hit hard but suffered no ill effects.
Dennis
http://www.youtube.com/watch?v=vBgWUceKmR0
2;10 into the video shows the final flight including the hard landing. If you look carefully you can see the wire stretching across the landing gear.
Propworn is offline
Old 11-30-2013, 04:28 AM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a beam mount so standoffs are out of the picture. If I do put any thrust in it will be with washers. I am going to centre the engine in the same planes (NPI) as the previous engine - centred side to side but closer to the top than to the bottom.
Quote:
Dennis
I'm pretty sure we'll be okay on weight with the stock control surfaces. As for weight and balance, the stock fuel tank was right behind the firewall; this one will be much closer to the CG. I will move the batteries back for balance if needed. And I will reinforce the landing gear if necessary. This is not the stock gear:
grosbeak is offline
Old 12-01-2013, 09:49 AM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I started the mounting process by holding the engine in place and marking the first bolt hole. I drilled that hole, then bolted the engine to the plane with the one bolt. Not a good idea for flying, but perfectly stable in the shop.
In the process of marking the other holes I re-learned that the beam mount bolts were too long and get in the way of the transfer punch I was using. Out came the rotary tool and soon after the bolts were shorter. Note the extra nuts - it's a habit of mine to thread a nut on first to help re-form the threads after the cut.
In the end I decided not to relocate the bolt holes in the beam mounts. As a result, the port side bolt holes in the firewall came through the tri-stock...
... so I removed the tri-stock. Some of it will reappear a few posts down.
grosbeak is offline
Old 12-01-2013, 03:02 PM
grosbeak
grosbeak's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bolted on - view from the front.
And from the back.
Throttle arm with ball connector.
Throttle tube drilling hole marked.
grosbeak is offline
Reply
Display Modes
