Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Super Sportster .90-1.20 CG issue
Reply
Old 11-24-2013, 03:32 PM
jsf135pal1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Super Sportster .90-1.20 CG issue
I just finished building this kit and installed everything including OS .95 ax motor and according to the CG Machine I need to add 12 ounces in the nose. I set the machine at 4 inches which is about 32% of wing chord and I placed the plane on it upside down. I have heard they are tail heavy but almost a pound?? Has anybody else had this issue with this plane?
jsf135pal1 is offline
Old 11-25-2013, 04:49 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have never built the 1.20 size. but the three smaller versions that I've built, all required nose weight.
If you have everything moved as far forward as possible, just add the weight and go fly.
TomCrump is offline
Old 11-25-2013, 08:22 AM
daveopam
Moderator
daveopam's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can you slide the motor forward any? It should balance right on the main spar when inverted.
David
daveopam is offline
Old 11-25-2013, 02:25 PM
jsf135pal1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
David
I messed up!!! I was trying to balance it on a very uneven surface so I just found out. I only added about 4 oz. in the nose with CG at 4 5/8" which is 34% of total wing chord. Thanks for the help.
Old 12-02-2013, 09:06 PM
Super08
Super08's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built one back in the early 90's with an ASP .91 and had to add about 2 oz of lead to the nose. It is still flying today but now has a 1.20 stroker on it.
Super08 is offline
Old 12-03-2013, 01:11 PM
yak86
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a Saito 150 on mine, with the servos just aft of the wing in a compartment, it didn't need any nose weight.
I've found that I like it a little tail heavy. But for the first couple flights your going to want it right on.
yak86 is offline
Old 12-03-2013, 03:53 PM
jsf135pal1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks yak86. What did you use for your CG measurement? How many inches from leading edge?
Old 12-03-2013, 04:49 PM
yak86
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think it was at 4" back. I had a small piece of lead next to the motor but that came lose one day and i decide to fly it and it flew fine. so its alittle tail heavy now. I think with this plane theres alot wiggle room in the CG.
yak86 is offline
Reply
Display Modes
