SHRIKE CLUB # 1
#253
RE: SHRIKE CLUB # 1
i am looking to put a webra 55gt on one of the .40 size. We are going to build from kit. Has anyone used an engine of this size on one, the weight of the webra is the same as a .46. Will the plane handle the the speed the Webra will produce?
#254
NJ
RE: SHRIKE CLUB # 1
all I can tell you is build strong . I have a rossi .65 on a .46 size plane and all it does is rips the covering off of the plane. I had to reinforce the tail with fliing wires ans the landing gear. I also put screwws thrught the wing tube with a wooden dowel through the aluminum tube. Get My Drift ?
#260
NJ
RE: SHRIKE CLUB # 1
i suggest you do , just to get an idea of how it flies. I wrecked mine not knowing the elevator is unresponsive at a certain speed. So, one of the mods mentioned for a kit is making a bigger elevator.
CAP
CAP
#261
RE: SHRIKE CLUB # 1
How does the shrike fly I didn't relize you had one. My buddy has a diamond dust, we both have wild wiz's. I didn't want anther plane just like his. So this was the next best option for the money. I found a website with one that has dual rudders working along with retracts it looks to be real fast and stable
#262
NJ
RE: SHRIKE CLUB # 1
once trimmed out it flies great , but that is it , you have to fly it . Unlike my Machracer it does not slow down to walk speed, and you have to land it on high rates for more elevator control.
#264
NJ
RE: SHRIKE CLUB # 1
yes the Mach Racer is a modeltech plane. I wrecked one sold it and bought another one which has been flying great for over a year now. I have a OS .46 and a tuned pipe on the nose. It is really fast but easy to handle.
#265
NJ
RE: SHRIKE CLUB # 1
Just finished building the Shrike 10 with an OS 32 sx stuffed in the nose. Wondering about balance. Looking at and measuring the plans I come up with 4 13/16" from wing root at fuselage. Wondering what you've come up with and do you balance upside down or right side up ?????? Thanks...
#266
NJ
RE: SHRIKE CLUB # 1
i just checked my plans and instruction manual and could not verify the COG. I do remember balancing it on the 1/4 inch spar right side up . Good luck with the maden flight. If you have not set up dual rates do so and land with high rates so you do have to come in to hot.
CAP
CAP
#267
NJ
RE: SHRIKE CLUB # 1
To all those that have stuffed a 32 into a shrike 10, about how much weight was added to the tail... I'm looking at 3oz even with the battery in the back. CG at 4 3/4" Sound about right????????
#269
RE: SHRIKE CLUB # 1
ORIGINAL: europatc74
The 15 will give way to an OS 25FX this winter. I will be moving the firewall back some, about 1&1/2 inch. Does that sound about right? I built a hatch in the back for a 270mah NiCad and don't want to add more weight than necessary. It's at 33 oz now and builds nose heavy with the 15.
#270
RE: SHRIKE CLUB # 1
ORIGINAL: BCarter
3. Has anyone mounted the motor sideways to try and lower the carb? I read in some threads that this helps with the problem of leaning out in tight turns.
#271
RE: SHRIKE CLUB # 1
Using the highly innaccurate balance with finger tips method. I got 5&1/4" for the CG, I think it lands slightly nose heavy at this range. Will try to move a little further back during the remake.
#272
NJ
RE: SHRIKE CLUB # 1
I had spoken to the people at Lanier and was surprised to learn that they had originally installed a 32 when designing the plane but due to the insane speeds they opted for a smaller engine. The only modification to the air frame was to extend the nose when installing the the larger engine. Nothing said about moving the firewall back.
#273
NJ
RE: SHRIKE CLUB # 1
If you are worring about weight , you might want to try to make it an EP Shrike. That is the only why I can see keeping a great deal of weight off the Shrike 10. I really don't recommend moving the fire wall back, I went from a AP .15 to a OS .25 and added the weight of a C size battery in the tail and did not notice anything but more speed.
#274
CA
RE: SHRIKE CLUB # 1
Mine. OS15FP not pictured. If you see someone flying it please punch them in the face and take it from them. I'll pay the shipping. This plane was stolen from my garage. I think I'm finally over it and might build another one.
#275
RE: SHRIKE CLUB # 1
What a bunch of ***** holes. You should nail it down rather easily by posting on RC Ads web sites ... [:-] Or maybe was it simply trashed... And no, don't punch him in the face, it could be a totally honest guy who just bought it 2nd hand
Mhhh. It then depends on the spinner, as my friend used a "heavyweight" alu spinner on his os.32 Shrike. It balanced correctly with no lead but with the firewall moved 2 cm backwards. Not moving the firewall backwards on .32 sized engines indeed requires making the fuse a bit longer. Moving the firewall backwards is simple, as Lanier only partially cut the firewall mounting holes. Just glue them back in place, and cut two other ones 2 cm behind, or adjust to your needs to have the back of the prop just in front of the fuselage front end.
