Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
SHRIKE CLUB # 1
Reply
Old 05-24-2009, 05:00 PM
  #526
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SHRIKE CLUB # 1
They are equivalent - might try a 7 x 4. Checked the Tower Hobbies manualand it recommends an 8 x 4.Something like that should work pretty well.Usinga lower pitch - it's like starting off in first gear. Good for lots of RPM, which will make it pull a bit btter and not crap out at the start if it's over pitched.
Good Luck
Cambodia eh!
Actually sounds pretty exciting.Stay safe.
Pete
4dogspete is offline
Old 05-30-2009, 02:28 AM
  #527
Alessandro 78
Alessandro 78's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some updates abput my engine setup: finally I tested on bench the engine with the pipe.
- propeller APC 7x6
- plug os A8
- fuel 10%
- header lenght about 3 inch
total RPM: 16.800 stable!
originally the rpm were between 13k to 14k
The engine becames really hot [:@]
I hope that in flight the speed could reduce the temperature
I'll post as soon as possible more pics, and a new flight report.
Alessandro
Alessandro 78 is offline
Old 05-30-2009, 05:24 AM
  #528
Alessandro 78
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
some pics about the new installation
To avoid pipe came out of the model, I realised a small aluminum support with a piece of silicon tube.
we will see if this solution will hold the pipe during the flight.
bye
Alessandro
ID:	1208667   Click image for larger version
ID:	1208668   Click image for larger version
ID:	1208669   Click image for larger version
Old 05-30-2009, 10:21 PM
  #529
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: prundel@cox.net
OK Here it is - my first shot at a .10 size Shrike. Powered with an K&B 3.5 (.20ci). Using HS-81MG servos in the wings for the ailerons. You can seethe hatches I made for access to the aileron servoson the photo of the underside. 250 mAh battery all the way in the rear including another 3 oz weight back there. I apologize for pleasurizing the stripe scheme from one of you guys - - Idid like the chevrons or darts or whatever they are.
Final all-up dry weight is 2# 6 oz. - I tend to build heavy no matter how hard I try to build light. And it's all ready for this holiday weekend - except that my wife has plans to go away. So it'll have to wait a week or so.
I love those K&B 3.5 rear exhaust engines, and nice job on the plane too.
Doin up a Shrike .10 w/ carbon main spar and a few other mods to handle a OS .25 vrdf engine w/ tuned exhaust, I can't wait to finish.
smoknrv4 is offline
Old 05-31-2009, 06:19 AM
  #530
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the kuddo's - still haven't flown it yet.
Get to show it off to the club at the monthly meeting this week.
Most of these members are giant scale WWII buffs, so I kind of stand out!
Do post some pics when You're done.
Old 06-04-2009, 08:23 PM
  #531
skyflyer47
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You guys are doing a fine job with those shrikes and wonders. Good luck with the maiden flights.
skyflyer47 is offline
Old 06-25-2009, 05:20 PM
  #532
badger5964
badger5964's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well finally got the Shrike 40 piped tuned. The Fox 46 ABC is turning the 9x9 APC at 14800 on 15% Omega. I like the plane but miss my sport planes. The high speed is great for fun once in a while, but it won't be my favorite. I am just not a speed freak.
badger5964 is offline
Old 07-02-2009, 07:44 AM
  #533
Greg5001
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all! This is my first posting to this site as a member.I have been reading many post as a quest. I need some help.I have plan "Shrike 10" and need drawings airfoil for wings.Could you send me the drawings. Best regards.
Greg5001
Greg5001 is offline
Old 07-10-2009, 06:41 AM
  #534
GregG
GregG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did a scratch build and picked an airfoil that looked about right. It was a symetrical nasa tail foil that I thinned to 6%. The wing blank was cut from blue foam and then vacuum bagged around a carbon fiber spar and leading edges.
The little guy went like a bat outta heii until one over exhuberant launch pulled the battery into the back of the fuse. I felt the big "CLUNK" at the end of the throw. The extreme tail heavyness made it impossible for me to regain any control and it went in hard. The only thing that survived was the wing, go figure.
GregG is offline
Old 08-02-2009, 12:50 AM
  #535
Harlan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pete:
Its now August and I'm replying to one of your posts from back in the spring. I have a K&B 3.5 with rear exhaust and it has a header fitted. I inherited the engine, so I don't know that its a Mac's pipe, but it appears to be. I inherited a few pipes along with it. Most were probably for a .40 size engine since they were 15 inches long, but there is one that is 7 inches long. I am attaching a pictures of the engine, the header and the pipe. The point is, there not only appears to be a header but also (maybe) a pipe for your type of engine. I just can't confirm that these are Mac's products.
Harlan
ID:	1248292   Click image for larger version
ID:	1248293   Click image for larger version
Harlan is offline
Old 08-02-2009, 06:18 AM
  #536
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Harlan
Saw your photos and it sure looke like the K&B 3.5.
Originally the later models came with the funky dual exhaust that shows on my Shrike and a remote needle.
So yours looks like a bit of an older one.
I am not a pipe person, but seems like that should work pretty well.
FYI - mine runs about 15k with an 8 x 4 prop with the funky exhaust.
You may be able to get any OEM parts from MECOA.
The bearings in mine were totally rusted from my poor storage. I ordered a new set and it's smoth as silk.
There may be other parts @ MECOA as well.
You may be able to do a guestimate by looking at the MACS web site and see what they recommend for a .20 size engine. But I think the pipe you put in the phots is probably the right one.
My general rule is - "put it together and fire it up"
I don't think you can hurt it if the pipe is the wrong length. It just won't "get on the pipe" which should be up around 16k - 18k rpms.
Good luck and let me know how it comes out,
Pete
Old 08-23-2009, 04:04 PM
  #537
smoknrv4
smoknrv4's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is the MACS wizard pipe set-up for the RK-20 ducted fan unit popular in the late 70's early 80's, it works good for a prop plane too, nice and compact, I have the same pipe set-up on my Shrike project, only the engine is a OS .25 vrdf, check out my thread in the extreme speed prop plane forum.
http://www.rcuniverse.com/forum/m_9034206/tm.htm
smoknrv4 is offline
Old 08-25-2009, 12:58 AM
  #538
jakomcbrain1973
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was thinking of doing a twin EDF version of the Shrike. (Sort of like a Horton HO-229 style intake set-up) Has anyone seen anything like that?
jakomcbrain1973 is offline
Old 08-27-2009, 11:40 PM
  #539
FX4L2CX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey everyone,
Here's my 3rd shrike 10 and I also have a 40 in the building process that you may be able to see in the background..
this 10 size has a RJL Cox .15 Conquest with a Mac's tuned pipe and an APC 7x6. I had to remove the perry carb and I put on an OS 11J carb and now it idles and transitions perfectly and it's killer stable even at full throttle..( it only took me 3 tries to get it right).
ID:	1264425   Click image for larger version
FX4L2CX is offline
Old 08-28-2009, 07:35 AM
  #540
crashpro2000
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FX4L2CX ,,
Where did you get your 40 kit, would love to get my hands on 1
crashpro2000 is offline
Old 08-28-2009, 08:17 PM
  #541
FX4L2CX
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I traded it for an airplane that I had, that another club member wanted...it had been sitting brand new in the box for a year or more. I wish I could find another 10 and 40 kit for backup.
ID:	1264878   Click image for larger version
FX4L2CX is offline
Old 08-29-2009, 06:52 AM
  #542
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recently saw a 40 Shrike kit on Ebay.
Didn't bid on it, but probably should have!
Check ebay - one will show up periodically.
Old 08-30-2009, 12:49 PM
  #543
Mustang Fever
Mustang Fever's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found someone who copied the 40 plans for me, and traced the rib carriers from the kits to produce rib patterns. I'm going to build at least two of them. The first will be a 35AX powered hand launched, as light as possible. For the second I'd like to do retract gear (B&D air) and maybe a Jett 35 rear exhaust.
I don't know what it is about this design that is so attractive. I've had four of them, 2 of the 10 size and 2 of the 40, and all of them were destroyed in crashes, but here I am again.
ID:	1265879   Click image for larger version
ID:	1265880   Click image for larger version
ID:	1265881   Click image for larger version
ID:	1265882   Click image for larger version
Mustang Fever is offline
Old 09-02-2009, 04:03 PM
  #544
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just posted the 40 size on fleabay if anyone is interested. I will never get around to building it.
Thanks, MikeB
WMB is offline
Old 10-04-2009, 08:24 AM
  #545
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally did my maiden flight on my Shrike with a K&B 3.5 (.20) engine.
It has a tendency to go up at full throttle, and I can't seem to put enough down throttle. It also has a tendency to roll left.
Do I need to add some down thrust or right thrust?
Slow flignt seems to be just fine.
Any help or suggestions would be appreciated.
Pete
Old 10-04-2009, 09:15 AM
  #546
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like it may be nose heavy. Mine came out nose heavy with both the 15 and 25. Does it need a lot of down elevator to fly level while inverted? Mine rolls to the left on launch, that's normal.
Have fun with it, MikeB
WMB is offline
Old 10-04-2009, 09:48 AM
  #547
4dogspete
4dogspete's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: WMB
Thanx WMB
The balance point is per the plans. I'd sure hate to make it tail heavy!!! Suggestions on balance point?
I haven't tried inverted - 'twas quite a handful just trying to get the trims even close to right - except for flying slow for a landing - lands like a kitten.
I was hoping for a high speed low pass, but kicking in throttle makes it a serious handful!
P
Old 10-04-2009, 10:05 AM
  #548
WMB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My original with the 15 was balanced at the recommended spot, but flew nose heavy. My notes show recommended at 4 7/8", flying at 5 1/16" and still feeling nose heavy. I moved the throttle servo back after that, but did not check cg.
With the 25 up front, I moved firewall back but still need to move things around to get the cg back. It is currently at recommended.
It seems like all my planes fly nose heavy at recommended CG. Benefits of correct cg are:
Slower landing speed
Easier inverted flight
More responsive elevator
More neutral handling in general
The covering started coming of mine. So it needs a covering job, I would also like to move more stuff to the rear if possible. It is cramped as is. It is fast with 25 and 9x4 apc. Haven't had the nerve to try a faster prop. Gets small fast!
WMB is offline
Old 11-10-2009, 05:22 PM
  #549
Mustang Fever
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I did a build thread on the one I'm building from plans, just started covering it today.
http://www.rcuniverse.com/forum/m_84..._1/key_/tm.htm
It has removable, fixed trike gear so I can have the option of "normal" or "scary" takeoffs. The weather here has just turned really nice, after one of the worst Octobers in memory, so I should be able to maiden it sometime this week.
Old 11-14-2009, 10:19 PM
  #550
helifryer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey yall. im new to RC Universe. im an RCGoups guy - but they dont have such a great thread on the shrike 0 so here i am!
today at a mass swap meet i was looking for something to put my .25 into. i found this little gem!
bought it for only $30 from a woman who claimed that with an OS.25, tuned pipe, and 8X8 prop it would easily do well over 110 mph! (she also threw in a motor mount
i love the covering scheme! it looks perfect. there isnt really any damage at all.
mine is different from others i have seen though, because it 1 - has no canopy/cockpit. 2 - the motor will just mount ti the firewall - there is no compertment. 3. the ailerons are controlled by 1 servo INSIDE of the fuse (no servos on wings that strip everytime i land)
the gear i have for it is a magnum Pro .25, 3 standard sized futaba servo (big, but they r what i got. will have to do some modding to fit em in. ) and i plan on getting a spektrum 6200 fullrange rx, and a new trustworthy rx battery. i think ill go with a 8X4 prop to start with. then ill try a 8X8 after i get a hang of it. later on if i really feel confident, ill try adding a tuned pipe to really make it scream
here she is!
Helifryer
ID:	1314280   Click image for larger version
ID:	1314281   Click image for larger version
ID:	1314282   Click image for larger version
ID:	1314283   Click image for larger version
helifryer is offline
Reply
Display Modes
