Hanno Prettner Stratos Delta
Does anyone have a copy of the plan for a Stratos delta (see pics)? This was about a metre span, made from flat foam & designed for a 40 or thereabouts motor. All I need to know is the dimensions of the wing, simple drawing will do, the CG location & the 'up' trim & control throws of the elevons. I have a friend with a microturbine in a foam delta but the little turbine has a bit too much go. - John.
