Twist 60
FL
Twist 60
I had a twist 40, and really liked it. Unfortunately, I still have... the wing. You guessed it, I found the weak spot in the fuse. Does the 60 have that same weak spot?
RE: Twist 60
For $99.00 what can you really expect. It's a good plane for the money. Remove the covering on the wing and reinforce it, then recover it. Should be fine. Cheap ARF's are just that CHEAP!!!
Gibbs
Gibbs
