How does a low wing plane fly with no dihedral?
Hi, Just wondering if anyone has experience with a low wing plane with no dihedral. I have a wing with no dihedral I've considered incorporating into such a design, so if anyone has tried this I'd like to know how it flies. Thanks
My Feedback: (9)
RE: How does a low wing plane fly with no dihedral?
The dihedral only helps the plane right it's self. You know it tries to keep the wing level. So a wing with no dihedral will stay where you put it. It may have to land a little faster other than that you wont know the difference in the air.
David
David
My Feedback: (85)
most low wing planes have diheidral. so do the extra 300's and such it is used to counter the opposite roll when rudder is applied. If you look closely at a lot of aerobatic planes such as pattern planes imac planes etc. the top of the wing will be straight across leading some to believe that there is no deheidral when in effect the wing ribs are tapered so when you look at the wing from the bottom you will see the diheidral.
Dennis
Dennis
Yes. My Contender 60 has no dihedral. Just straight spars right across the wing. Flies great. Most (maybe all?) pattern planes have no dihedral (or appear that way according to the above post). Sweeping the wing back also has the effect of dihedral. It makes the plane easier to fly if you want one that is neutral and only goes where YOU point it. But it does mean that YOU have to be in control at all times and it will not be semi-self correcting for roll in level flight.
While on the subject of low wing no dihedral, lets assume it is a tail dragger. When taking off do you have to use any down elavator. I have never flown a taile dragger. Thankyou Herb Calvin
Calvin, I am referring to taildragger, thats all I fly. No, you can't use down elevator on a taildragger on take off, it will make it pitch forward on its nose. Its best if the plane is trimmed neutral or a slight touch of up. My takeoff techniqe is to gun the engine and get the plane moving as fast as possible down the runway, then a touch of up will do it, sometimes it doesn't even need that. There are some schools of thought that you accelerate slowly as you go down the runway like a full scale tail dragger, I find this always results in a ground loop.
The accelerate slowly (a 5 count from idle to full throttle ) will provide more control over the plane. The key to this (or any take offs), especially with a tail dragger, is to watch the plane. As soon as the tail lifts off the ground feed in A LITTLE right rudder to compensate for the prop torque. The amount of right rudder you need to feed in will vary from plane to plane. Taking off like this will avoid ground loops.
Tri gear planes aren't as bad with the effects of prop torque because the nose wheel helps to hold the plane in a straight line.
