funtana x 50 question
Hi,
i am at the phase of mounting my O.S. .46 AX engine on my HANGAR 9 FUNTANA X 50.
i noticed that the muffler touches the slanted part under the firewall. CAN I CUT A HOLE IN THIS PART????!!!!! I noticed that it is balsa.
I am also going to install a DUBRO landing gear. it ha four mounting holes which are wider than the actual base plate on the fuselage.
can i put some extra plywood to expand the gear mounting plate?????
RE: funtana x 50 question
G'day Mate.
You can buy a small extension, from OS, it moves the muffler further away from the motor, that should cure your problem, without any cutting.
I had to put one on a Sportsman Aviation, Mad dog, to allow more right thrust, works good, & cheap too.
thanks
do you think i hould reinforce the inside by brushing a thin layer of epoxy??
the landing gear plate is nearby
Hi, i am using a jr 7202 radio with the servis that come with it, but im using a 6 volt battery to speed things up a bit. Does anyone have the same setup or similiar, and what % of exponential are you using on high rates. thanks
