Sport Flying This forum is for those that like to fly just for the enjoyment of flying, and all the airplanes that help them. Discuss here the joys of flying and the airplanes that help you enjoy it.
Cap 232
Reply
Old 01-01-2007, 09:09 PM
rednekk58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Cap 232
Hi All,
Getting things tidied up on a Cap 232 from Nitro Models Com. Directions are almost useless. Will try a smoke system this time. I've never attempted smoke on any plane. This is a .60 2c, 90 4c size I'm using a OS .60 with a slimline pitts muffler. I have a 13 / 6 Master Airscrew composite prop since I'm using a 3" spinner. Throws seem a bit small, 10 and 12 mm. ail. and elev. Looks like it will come in well under 7 lbs. Anyone flying one of these? What to look for, quirks, maybe under powered? Any smoke suggestions? Where should I place the check vavle, before or after the T.M.E. pump?
Here's some pix ,I think?
Red
ID:	588644   Click image for larger version
ID:	588645   Click image for larger version
rednekk58 is offline
Old 01-27-2007, 04:27 PM
Bonz-RCU
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cap 232
Hi.sorry cant answer your questions but I have a world models CAP 232 46R ARF.Just a tip for what its worth.I use a fill valve thats in line with the fuel supply line.When you plug in the fuel filler it shuts off going to carb and fills the tank.I put one of these in the pressurising line from the muffler in reverse.I plug in the filler plug which has about 6 " of tubing which vents tank until full.no mess and no flooded carb.I never installed the third fuel line and had to guess when tank was full by waiting for fuel to leak out of muffler.very messy practice.
Bonz-RCU is offline
Old 01-27-2007, 05:18 PM
rednekk58
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Cap 232
Thanks Bonz,
The engines on it's side with a pitts muffler, I think it will be ok. I'll keep your advice in mind though if I run into problems
Reply
Display Modes
