engine recomendation for tiger 2
RE: engine recomendation for tiger 2
I had a tiger 2 with a ST.45. Flew fine, but I was getting into four strokes and bought a used Saito .56 which was a great combo. I have used both the bent into a 180 degree hoop and "bell crank" throttle linkage and prefer the bell crank. You can make one yourself using an extra servo arm or wheel. Just screw it to the side of the motor mount and run your throttle pushrod to it and then pick a hole opposite and run back to your throttle arm. very simple and effective.
