Best simulator
Best simulator
I don't know if this is the right place to ask, but I'm looking for the best simulator.
I think I'm a real good pilot with many hours of flying, started in 1974.
But I want something to play with during the cold and dark winter.
To work on my 3D skills.
I was thinking of Great Planes simulator but I'm not a computer wiss so I don't know.
My Feedback: (25)
RE: Best simulator
I've only used RealFlight G3.5 and now G4.
I regret selling my G3.5. The new version is a downgrade in my opinion. Physics are less accurate and all models from previous versions will need to have all their parameters reworked to function properly in G4.
I'm now considering selling my G4 to give Reflex XTR a try. [&o]
RE: Best simulator
ORIGINAL: Bernowt
The physics are the same.
The only observed changes are with increased control surface authority at extreme deflection, but this only affects a few 3D planes.
KE has publically stated that their physics engine code is unchanged in G4.
No parameters have to be "reworked" for G3.5 models to function properly in G4.
With the first release of G4 there WAS an issue about the control switch mapping that was resolved with an update.
If you IMPORT the G3 models after updating G4 using the launcher, the mapping problem goes away.
My Feedback: (24)
RE: Best simulator
martenson:
I have only used RealFlight. I am thoroughly happy with it.
However, since you are in Europe, I suggest you take a look at the Reflex IVOL system. The Reflex looks really outstanding from what I have seen in previews and I know there is a huge following in Europe with several websites dedicated to designer models being created. The new IVOL controller also looks quite amazing. However, it is rather expensive but if you can afford it..........
RE: Best simulator
Thanks for your help guy's.
I just ordered a RF G4.
But what's the deal with the european style and USA style, I and 99.9% of the guy's I know use mode 2.
So the mode 1 and mode 2 is not really that easy, the mode 1 is more german, finish type I think, I might be wrong.
My Feedback: (25)
RE: Best simulator
That's not true.
Yes, it is. http://www.knifeedge.com/forums/showthread.php?t=18696
Changing your story?
Not for me. I even had a JET doing loops about itself at 1/4 throttle.
The U.S. Gov't publicly stated there were WMD in Iraq.
So why does the same model behave entirely different between the two versions? You may want to refer back to the thread YOU started.
I'm aware of that and I didn't mention any issues.
[/quote]
[/quote]
RE: Best simulator
ORIGINAL: Bernowt
That's not true.
That's not true.
No. You should read on. Maybe you missed the rest of the coversation...
ORIGINAL: Bernowt
ORIGINAL: Bernowt
ORIGINAL: Bernowt
As I stated the effectiveness at extreme deflections is what is more pronounced.
It is not noticible on most models. with surface deflections of less than 30-35 degrees.
Above that is where a difference may be noted, which while trivial to adjust, does represent a slight change.
ORIGINAL: Bernowt
They do not.
My Feedback: (25)
RE: Best simulator
Opjose,
I read the KE forums daily. *I* have seen the differences you yourself have acknowledged and are now dismissing.
The planes I'm speaking of are user-designed models. YES, they fly/behave differently between the G3.5 and G4. End of story!
I'm not going to drag this on into a knowledge/experience war. Besides, The thread-starter has already made his choice.
RE: Best simulator
ORIGINAL: Bernowt
Opjose,
Opjose,
ORIGINAL: Bernowt
To paraphrase you... "End of Story".
I would be complaining all the more loudly if they did.
It would be nice to know which plane you are talking about vis-a-vis the jet you looped so I could have a look.
My Feedback: (13)
RE: Best simulator
ORIGINAL: Bernowt
Opjose,
Opjose,
I don't want to fool with any of that. I am not a computer guy and have no desire to be.
I'm told that this KE Forum provides real-time assistance for RealFlight products. If so, do they tolerate computer-stupid types like me? I've been flying R/C for 21 years; but can barely get around inside a computer.
Your opinion would be appreciated.
RE: Best simulator
ORIGINAL: Steve Campbell
What about the models that are in the software already?
They fly well, as per the planes they are modeling.
I'm looking for a sim for #2 grandson (and for me, okay... , but mainly for him) and am getting so much conflicting information I'm about to short out. The problem is, my new 'puter uses Vista for an OS. On the one hand, I've got folks telling me its no big deal; then, in the specific forums on that brand of sim (AFPD, for example) I read a post about this or that not working, you need a patch, download this BEFORE installing the patch, you might have to un-install and re-install...
The Minimum, or sometimes the suggested, are often barely enough to get things running.
In addition the OEM computer manufacturers ( cough *Dell*etc* cough ) often hide the capabilities of the hardware from the consumer.
This permits them to sell you one or two year old video adapter technology at a reduced price but indirectly imply that it is the latest and the greatest.
With all 3D programs the speed of the processor and hard disk, coupled with the processing power of the video card are the greatest factors for reliable and satisfactory performance.
Scrimp on a video adapter ( as the OEM's do ) and you'll be one of those complaining about problems with a 3D sim.
So if you haven't already purchased a computer, select carefully.
If you have, you may also need to upgrade the video controller...
Many computers have DX9 installed, but the adapters are NOT DX9 compliant.
Throw a recent sim like G3/G4 onto the non-compliant machine and you'll have problems.
That being the case then you should purchase a HIGH END ( more money! ) computer system if you haven't already done so. One ideally designed for gaming and 3D work.
People who delve into the "computer stuff" can take care of their own machine's shortcomings and save a bundle by upgrading those components that are lacking.
To avoid this you MUST be sure that your computer meets and exceeds the software specs.
Typically a ton of newbies join. Many with the very problems that I've listed above.
When some are told that their machines may be substandard, they may start moaning and complaining that something is wrong with the software, etc.
There's a low threshold for THAT kind of stupidity... ( the problem is pre-existing and they don't want to deal with the expense or do anything about it, they merely expect someone to "fix it"... sigh. )
However for tolerance for REAL problems is high.
If you already own a computer your best bet is to post a detailed list of your computer's specification BEFORE you purchase any software.
That can be used to determine what may run well on your computer, and may help you narrow down your choices.
RE: Best simulator
Guess what arrived to day, a BIG package from Tower Hobbies.
I ordered on Friday and it arrives on Monday, might seem okey for you guy's but I live on the other side of the atlantic.
So from USA to Sweden over the weekend.
I'm impressed.
Take care.
I'm impressed.
Take care.
