4 Star 60 ARF or Tiger 60 ARF
PA
I'm sure this has been asked many times before but I did not find it. Looking for a plane for relaxed flying with no surprises. Easy landings and gentle characteristics. If you have an opinion, does it apply to 40 size too?
My Feedback: (551)
RE: 4 Star 60 ARF or Tiger 60 ARF
Pacific Aeromodels Knockabout 46. Can use either a 46 or a 61. The Tiger and 4* are both excellent airplanes, but I think the Knockabout is easier to fly low and slow and more fun when you want to kick-it.
www.pacaeromodel.com
Jim
Jim
My Feedback: (16)
The Tiger 60 is an excellent model, the original design guideline for this plane was pattern flying. This will make a smooth flying plane that tends to stay in the groove
The Four Star 60 was designed to be an easy flying sport plane that is easy to land and is the standard of Sport Flying comparison.
The Sig Four Star and the Goldberg Tiger are both fantastic flying sport planes in all available sizes - .40, .60, or 1.20 versions.
Both planes can be flown gently and will land as easily as most trainers. Both planes can be overpowered and flown like screaming banshees. Both fly well off of floats. Both are classic designs that do most everything fairly well and neither has any particularly bad traits. It's no accident that these classic designs are still around and still popular with pilots.
There are a number of airplanes that are rather derivative of these two classic designs. Tower Hobbies carries the Phoenix Models Dolphin .40 ARF that is embarrassingly close to the Four Star .40 in terms of design. The Kyosho Calmato Sport .40 and Sport .60 are practically twins to the Goldberg Tiger 2 and the Tiger .60. Nitro Planes carries some low wing trainer ARFs in .40 and .60 sizes that also look a lot like the Goldberg Tiger.
Fly either of them and you'll be delighted, fly both of them if you have the money and storage, try them in different sizes, try one of the imitators if they fit your budget better. Trying to pick between the Four Star or the Tiger is likely trying to choose between Grolsch and St. Pauli Girl; they're both too good to pass up.
Maybe you would like a "Stick"? I think Great Planes has a 40 and 60 size. There are also the Horizon Hobby versions. I have a Four Star 40. It is a nice plane. I like my Stick allot more. It will fly slow and it will fly fast. Pretty much goes where you point it. It can do acro's better than I can fly them. I keep adding planes and I keep flying my Stick.
Good luck.
Frank
Good luck.
Frank
I have had both a FourStar, and a Tiger 60. Both were a pleasure. IMHO the FourStars are a little
better for someone coming off a trainer. From a kit building perspective, the FourStars win hands
down. Of course, if you go the arf route that won't matter. [sm=shades_smile.gif]
w8ye
You are right based on my experience. Between a Stick and a Four Star the Stick will fly way better in the wind. The Four Star 40 is knocked around easily with gusts while the Stick is rock solid. With the winds we have out here I choose to fly my Stick more often. You don't realize it is windy until you set up to land.
Good luck
Frank
Good luck
Frank
My Feedback: (16)
If you don't fly in the wind, you are not going to fly much.
I've lived in this part of Ohio most of my adult life and to the west it is nothing but flat land and farm fields and that means wind.
But just a few years ago I had to live in the South East US off and on for 3 years. It was windy there also but not as bad as here.
If you fly a lot in the wind, at sunset, when the wind quits, you feel strange.
So why might a Stik fly better in the wind than a 4*? My understanding was that wind sensitivity is a manifestation of light wing loading, and mass. Higher wing loading -> less wind sensitivity; bigger (heavier) aircraft -> less wind sensitivity. Stiks have pretty low wing loading, right? So why are they better in a breeze?
ORIGINAL: glowdaddy
I am no expert, I know the Stick has a symetrical wing and the Four Star has a semi-symetrical wing. This may account for the solid performance of the Stick in heave winds.
The Four Star does fly faster than a Stick at WOT.
Ernie is right, get them both if you can. They are both nice planes.
Good luck with your choice.
Frank
Frank
Sir,
With all respect, Before I wrote my last reply I researched and found that Tower Hobbies is calling the Four Star 40 wing a Semi-semitrical airfoil.
Ref:
http://www3.towerhobbies.com/cgi-bin...&I=LXFKB0&P=ML
SPECS: Wingspan: 59-3/4" (1518mm)
Wing Area: 604 sq in (39 sq dm)
Weight: 4.75-5.25 lb (2.1-2.3 kg)
Length: 47" (1194mm)
Airfoil: semi-symmetrical, low-wing
But, with that said, both planes are great to fly. I have them both and I hope everyone gets them enjoys them as well.
Thank you
Frank
Ref:
Thank you
Frank
Any of the planes mentioned here can be flown in moderate wind, they just react differently.
I used to fly only on perfect weather days, needless to say I didn't get to fly as often as I
wanted.
BTW, Jackson OH. is pretty much BFE.
wanted.
My Feedback: (16)
ORIGINAL: SKYHI1
Sir,
Ref:
Thank you
Frank
Sir,
Ref:
Thank you
Frank
The picture is not my plane but one from another thread
Really, I didn't mean anything either. I just wanted you to know that I was not talking out of my you know what. And I tried to contribute to the post with researched info. I like both planes. I do think the Stick has some advantage in stabilty. To me the Stick will always be in my hanger in one form or another. With the Four Star if it crashed beyond repair, I am not so sure I would be in a rush to buy another.
Thank you
Frank
Thank you
Frank
