Flying wire connectors
TX
Greetings bi-wing Gurus,
I have acquired my first biplane (Ultimate 60) and flown it a couple of times. Great Plane! My question is, does anyone know of a better way of attaching the wing flying wires other than a metal cleavis? I find this type of connector very inconvient because of their strong spring tension (which is probably the reason they were used on this plane). Will the nylon cleavis be strong enough to secure these wires? Any suggestion would be greatly appreciated.
My Feedback: (16)
CA
RE: Flying wire connectors
ORIGINAL: sonnytex
I know rigging a bi-plane is some what of a pain when you get to the field..................but take your time and do it right!!! the option if you fail could be a plane that flies like crap or one that only flies once.
P.S you can also use fishing leader as cable. Just make sure you get the right size ( poundage rating) for your applacation I have used the plastic coated steel from 10 strand brand but really any of the plastic coated steel cable will work and usually it is a bit less costly than the other suppliers. My self I prefere the very very flexiable steel cable that Balsa USA has to offer. It comes in two sizes and they also have the swage fittings to go with the cable. It is very very good stuff. Use the smaller size on a .60 size or go to Proctor for other sizes in your power range.
If you are unsure of how to rig a bi-plane ( correct order) just let me know and I will send you the best way to do it. There are certain steps you want to use so that you don't rig in warps to your wings.
TX
SoCalSal,
Thank you for your information. I will abide by your experience and continue to use the metal cleavis. I guess I was just being lazy in trying to make shortcuts. But then again, isn't that what we all look for, a better, faster way to do something? Just goes to show you that tried and true way are best.
Sonnytex
Sonnytex
