RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Sport Flying (http://www.rcuniverse.com/forum/sport-flying-373/)
-   -   Tiger 60 w/DLE 20 (http://www.rcuniverse.com/forum/sport-flying-373/11314331-tiger-60-w-dle-20-a.html)
Leroy Gardner 11-29-2012 09:47 PM
Tiger 60 w/DLE 20
Has any of you put a DLE in a Tiger 60. It's being converted to tail drager and getting a bash job. Engine has been raised (thrust line) for added prop clearance and it looks like it's going to need a 16" prop so I need to know how long a gear I will need that will mount on a 4" wide fuse. under belly. All help is welcome, thanks.
bikerbc 11-30-2012 04:09 AM
RE: Tiger 60 w/DLE 20
How much did you raise the motor? The Du-Bro Super Strength gives me 2" clearance with the tail up and 2.75 tires and a 14" prop....
David Bathe 12-03-2012 12:07 AM
Raising the engine will have some adverse effects on the performance.
The tiger was used for many year as a simple pattern primer. The airframe benefited from a couple of simple mods:
Extending the rear fuselage/tail plane/fin 2" further back, larger rudder etc. One was lowering the engine thrust line 1". I did all of these on the smaller T2, very good results. For the larger T60 the engine was lowered 1.5".
If you want ground clearence, just use higher after market UC's.
Leroy Gardner 12-03-2012 09:28 PM
David I should have said I'm also raising the wing 3/4" and they will will be plug in kinda like a 300. the whole top foward 1/2 of fuse. is reworked and the shortened conopy section is removable for easy access of servos, batt's. and wing attachments " Oh", did I say it's being bashed some. I'm not worried about the changes, this will be no kitty cat when finished but it will still have the great flying traits it's known for.
Twin_Flyer 12-06-2012 05:20 AM
How is the progress on your tiger going?
Bill S.
Leroy Gardner 12-06-2012 04:23 PM
Quote:
ORIGINAL: Twin_Flyer
Bill S.
Bill you can see where I'm at on the build on the last couple pages at Kit Builders site under Goldberg Tiger Club, you may find it intresting. It's a fun build for me.
Leroy Gardner 12-25-2012 07:42 PM
Quote:
ORIGINAL: Leroy Gardner
Bill S.
It burned out there so I started my own thread, it's in Kit Builders under Intrested? I'm Bashing a Tiger 60
Twin_Flyer 12-26-2012 05:09 AM
I will check it out!
Edit: I looked for your thread but did not find it...
Bill S.
Leroy Gardner 12-31-2012 07:25 PM
Bill S.
Bill it should be easy to find, in RCAirplanes in the Kit Builders Forume, under Intresred? I'm bashing a Tiger 60.
It is a very unique build of this plane, wish I could do the URL thing. Leroy
Twin_Flyer 01-01-2013 08:59 AM
Found it.
I tried doing a search for it and came up empty. Seems the built-in search function leaves a lot to be desired!
I will follow along now!
Bill S.
Leroy Gardner 01-02-2013 02:38 PM
Location of build is at www.rcuniverse.com/forum/m_11326847/tm.htm
