SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
super tigre g20 ring replacement
Reply
Old 10-13-2011, 04:36 AM
grant118
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default super tigre g20 ring replacement
I have a made in china ST G20 that I want to replace the ring. The bore size is 1.280". Do I need to pull the cylinder out to get the piston/conrod out to replace the ring and if so how do you get the cylinder out? I am used to having a cyliner with a flange on the top that can be used to pry out the sleeve with a small screwdriver. Any help would be great. Also what do I use for allignment when putting the sleeve back in the block?
thanks,
chris
grant118 is offline
Old 10-13-2011, 06:08 AM
Bax
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: super tigre g20 ring replacement
The cylinder liner comes out first. You'll need to heat the case to get the cylinder liner out. Give it a gently press from below to get it out.
Bax is offline
Old 10-18-2011, 05:21 AM
grant118
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Bill. Is there any alignment pin, groove, etc to keep the cylinder lined up with the case during reassembly?
chris
grant118 is offline
Old 10-18-2011, 05:57 AM
Bax
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any alignment pin is inside the ring groove of the piston. You need to make sure it's on a web when the piston's installed into the liner. The cyinder liner just needs to be installed so that the exhaust port lines up with the exhaust port in the case. The head will keep it from rotating once things are all tightened down.
Bax is offline
Old 10-18-2011, 06:27 PM
grant118
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
10-4 thanks Bill
grant118 is offline
Reply
Display Modes
