If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 2 of 2
  1. #1
    Join Date
    Jan 2002
    Knoxville, TN
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    .45 ABC Mid range problems
    I have a ST .45 ABC that's giving me fits running in the mid range. I'm running club 15% fuel, MA 10x7 prop, and a Thunderbolt R/C plug, and it loads up running in the mid range and won't transition well from idle to full speed. I've even tried rotating the spray bar a little since this is adjustable on the ST carbs; where is this supposed to be set? With the fuel nipple horizontal or at a slight angle? Any majic fixes for STs you know of?
    This engine really looks well made and is powerful at full throttle, so I'd like to see it running well.
    Thanks for the help and all the trouble shooting you do,
    Joel
    P.S. What would it take to get you in trouble so that you'd lose your job, and I could take your place?
  2. #2
    Join Date
    Jan 2002
    Tuscola, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Hi agin joel! thanks for starting a separate thread, its far easier.
    To properly set up your carburetor, there are a few steps...
    Make sure the spraybar is set so that the fuel slot is pointed straight down the center of the carburetor. You will have to look through the carb from the bottom, with the venturi opened to full. Loosen the two screws next to the high-speed needle valve to rotate the spraybar so that the slot is centered.
    The idle needle can be seen in the slot of the spraybar. It looks like a piece of wire that has the end squarely cutoff. It should be less than one-half way across the slot when the venturi is opened to full.
    The high-speed needle should be opened about 2-1/2 to 3 turns out from closed.
    All of these settings are very rich. You'll have to start the engine at about 1/4 to1/3 throttle. Once the engine starts, advance the throttle to full. You can then lean the high-speed needle until the engine is running just rich of peak RPM.
    Once you have the high-speed needle set, you can retard the throttle a bit and use the idle needle to adjust the engine. Retard a bit, and adjust. Keep doing this until you have reached the desired idle RPM and mixture. Remember, since we started out with an intentionally-rich setting, the idle mixture will have to be leaned.
    Finally, the midrange can be adjusted by rotating the spraybar a hair. Just loosen the two screws next to the high-speed needle and rotate the spraybar just a tiny bit. Either direction is OK. This will help you get a good transition and midrange.
    Sincerely,
    Mrs AnnMarie Cross
    Owner, Cross Winds Stables and Equine Rescue, Inc.
    an Illinois 501c3 nonprofit charity corporation
    http://crosswindseqresq.org
    Please consider donating RC items you\'re no longer using to help us to help the horses!
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
