SuperTigre Engines Support Ask Bill Baxter your questions regarding the SuperTigre line of engines.
aluminum engine mount alloy?
Reply
Old 02-27-2015, 05:47 AM
xkadet
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question aluminum engine mount alloy?
anyone by chance have an idea which aluminum alloy is used in aluminum engine mounts such as that of the ST 4500? This appears to be a molded engine mount and of lighter weight and typical plate and I was hoping to compare the strength modulus of the mfg mount with the new mount I am designing using 6061 T6. In this way I can scale the size of the mount to some extent and reduce weight. Any helpful comments would be greatly appreciated.
xkadet is offline
Old 03-03-2015, 08:12 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That information is considered proprietary and is not for public release.
Bax is offline
Old 03-03-2015, 11:01 AM
hugger-4641
hugger-4641's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Casting alloys are often proprietary. Extruded alloys like the 6061 T6 you mention are great for machining but are going to be difficult for any DIY home bending or forming. If you are going to maintain strength and reduce weight, you will probably need to go with a stronger 70xx alloy such as 7075 or 7068. These are very expensive alloys and do not weld well, but they would be stronger than 6061 of the same dimensions.
hugger-4641 is offline
Contact Us Archive Advertising Cookie Policy
