Parts for Older ST .75?
Hello,
I just purchased a much-used plane that included an older ST .75 engine. The engine is going to need some parts, such as gaskets, if I can ever get it completely disassembled; the oil has turned to cement.
Apparently there were at least two versions of the .75 and I'm not sure which one this is or if parts are interchangeable. I'm attaching a few photos.
Thank you for any information about parts availability you can provide.
Cheers,
Richard
Cheers,
Richard
RE: Parts for Older ST .75?
You have an older, SuperTigre S-75 engine. Some parts for it are still available because they're still used in the G-75 engine. Parts specific to the S-75 are no longer available, such as the gasket set, and case parts.
It all depends upon which parts you need.
The internal parts for the S-75 and S-75K were the same, just the case and head exteriors were different.
