Super Tigre 2300 or 3250 ??
My Feedback: (35)
I'm fixing to order a Super Tigre 2300 or 3250 the plane the motor will be mounted on will be a 1/4 scale sukhoi. Which motor would be the best for this?? Will either motor have the new carb's on them or will I have to pick up a new carb?? I also want to run a 3-blade on this bird any 3-blade prop recommendation's?? 16x8, 16,10??
RE: Super Tigre 2300 or 3250 ??
First off, what size engine is recommended by the maker of your model airplane? We'd stick within that.
When you're asking about "the new carb", we're not sure what you are asking.
Propeller choice will be dictated by the model's size, weight, and what engine you wind up using. The G3250 would normally be run in the high-7,000's, The G2300 should be run in the mid-8,000's. They should be propped accordingly, but we don't have any listing for a 3-bladed prop.
