ST2300 High-Speed Needle Valve Assembly
I originally posted this in the Glow Engine Forum but it should probably go here.
I had to remove my high-speed needle valve to fit a cowl. On removal I notice that it has a spring and a very small o-ring. It looked like the spring went on the needle first then the o-ring. I assume the spring is used to keep pressure on the o-ring. I looked at Tower's site and could not find a replacement o-ring which I'm sure will have to be replaced sometime in future. Any suggestions on where to get one? Neither part is shown on the pasrts list for teh engine.
Paul
Paul
My Feedback: (15)
OH
RE: ST2300 Needle Valve Assembly
Here is the link
http://www2.towerhobbies.com/cgi-bin...?&I=LXFY37&P=Z
Looks like all engines use this o-ring.
