part time idle on super tiger
MI
[&o]I have a super tiger G49 sport 2 Stroke. it runs top end and transfers throttle very good, at idle it will idle a few minutes or seconds then just quit, it dosen't matter what i do with the idle mixture screw. it might idle 2 seconds or 3 minutes but always quites. I have striped and cleaned the carb, It seems to load up then stall. I have leaned it out and richened it up a 1/16th turn at a time untill it wont run but no help. I am running sig 10% wit 20% oil 1/2 syth,1/2 casteroil. It does not seem to be heating up just loading up. It has very good compression and starts great, There is some end play in the crankshaft but very smooth turning and no side play on my dial indicator, do you have any sugestions ?
Thank you JimS[&o]
Thank you JimS[&o]
RE: part time idle on super tiger
You engine just isn't broken-in enough or isn't adjusted properly. Here's how to get the carb properly-adjusted:
http://www.rcuniverse.com/forum/m_1579985/tm.htm
