RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   SuperTigre Engines Support (http://www.rcuniverse.com/forum/supertigre-engines-support-163/)
-   -   S.T. GS45 Cylinder sleeve Question? (http://www.rcuniverse.com/forum/supertigre-engines-support-163/11273864-s-t-gs45-cylinder-sleeve-question.html)
jag215 10-23-2012 07:04 PM
I have a S.T.GS-45 that had a leaking head gasket. I ordered and replaced the gasket, while I had the head off I pulled the sleeve out to check it out and I put everything back together. At the field this past weekend I went to fly the plane (Kaos 40) and I couldn't get the engine to run. It looks like I am not getting a good prime. My question: Does that cylinder sleeve go in a certain way? It didn't seem to have a notch or key to line it up. Any help appreciated thanks Jag215
Bax 10-24-2012 06:56 AM
RE: S.T. GS45 Cylinder sleeve Question?
If you examine the ports on the cylinder sleeve, the port that is closest to the cylinder head end is the exhaust port. Just center it in the port in the cylinder casting. Later SuperTigre engines have a notch sawn into the lip at the top of the cylinder liner. This notch points towards the center of the exhaust port of the cylinder casting.
jag215 10-24-2012 07:37 AM
Thanks Big help, I had it in wrong. There is a little indent on top of the sleeve. I will center it with the exhaust port. What do you recommend for leaks where the muffler attaches to the engine? I have a small fuel leak there also. I have spare gaskets, should I replace it or do others just use gasket adhesive? Thanks Jag
