T-Rex heli For all you T-Rex lovers out there, this where you can post!
HK 600 question
Reply
Old 01-23-2012, 12:33 PM
Broken Blade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HK 600 question
I acquired 600 with no speed controller or batteries. Since funds are an object I was thinking about finding a used Align speed controller and I'm finding some decent prices on 22.2 v 3500mah batteries. Can anyone give me info as to if these battereis will work and is Align a good ESC and which size do I want. Thanks for the help.
Broken Blade is offline
Old 03-24-2012, 09:28 AM
ferretmaster
ferretmaster's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: HK 600 question
Iuse HobbyWing Platinum. The cost is low(er) and after using 8 of them on my fleet with no failures, recommend them.
I would go at least 80 amp for the 600...and even up to 100 amp for hard 3D and FBL.
ferretmaster is offline
Old 03-26-2012, 08:13 PM
Ybenjulkay2x
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
check out HK hobby, they have some descent lipo batt. I may consider going to 5000 mah instead of 3500mah.
I have also the hk600 and I used 2 3000mah 6s for forward flite (5 min each flite) 2 batt. just to balance its center gravity. also
I used 2200mah 3s to power the HK esc opto 80 amp + regulator to power the reciever.
Ybenjulkay2x is offline
Reply
Display Modes
