Installing servos on the T-Rex XL (HDE)
I assume you have to cut the top tabs off the Hitec HS56 servos and drill a new holes in the middle of the bottom tab to get these servo to fit right (collective/elevator/aileron)? I really can't see them working any other way, just thought I better check before I cut the tabs off.
PA
RE: Installing servos on the T-Rex XL (HDE)
ORIGINAL: Charlie
I just left the tabs on, and used my dremel tool to drill 2 new holes in opposing corners using the existing holes in the servo as a guide.
Don
