Thunder Power For The T-Rex 600
Just ran across this on the thunder power website.
TP5000-6SX
5000 mAh, 6 cells (22.2V), 6-pin balancer connector
Rating: 22C (110A) continuous, 30C (150A) sustain, 50C (250A) burst
Dimension: 50mm x45mm x160mm
Weight: 726gm
$319.99
SLewis
TP5000-6SX
Weight: 726gm
$319.99
SLewis
RE: Thunder Power For The T-Rex 600
jet22b, can you help me on the settings for MRC 989 charger. I just got it today and am confused on some of the steps. I have a brand new 12c 2200mah 3s apex lipo. So far I have it setup for lipo , Profile#0 , 2200mah , 3cell , 1.00 amp , auto cycle discharge 3.50 amp , auto cycle cut-of 4.00 , 136F degree cut off , time 130:00 , CYC 1 , but after cycle it says volt 0.00 and wont let me do anything, when i push + or - it says 1-d and can go up to 9. Im thinking thats the delay time I set at 2 for twenty min. I know this is alot to ask looking at what i just wrote, but will this work? Mike
Hi Mike,
I have yet to do use the auto-cycle on my charger, but it sound like you set a twenty min delay. You did the setup right. The unit will tell you is the cell count not right. I think it will work, if not reset eveything and try the amps 1.5 than 1.0.
Please let me know the out come!!
Sonny
Sonny
