Rotortech blades
ND
Rotortech blades
Does anyone know if the 320mm rotortech blades are going to be available for the Trex again? If not has someone tried the 350mm blades and do they work for the trex? I could see they would work if the tail boom was long enough but I don't think the stock tail boom would be long enough, so does anyone make a longer tail boom for the trex 450?
http://www.centuryheli.com/products/...?currentid=191
VA
RE: Rotortech blades
I think 350's are quite long for trex's probably it will make more stable but don't know if it will perform well.. I did try the 315's before but they are good for 3d flight which i don't like since its more agile...I'm more of a sport flyer so to me 325's are the best ones.. try the radix blades...
ND
The reason I want to try the RotorTech instead of going with another brand for now is that I have heard good things about them from some of the local pilots. I am using a set of Maverik blades when I fly and they work just fine, I asked about the RotorTech blades because they have been out of stock every place I check and I needed to know if someone might know where I could buy some of the 320mm if not I might try the 350mm.
