DX7 USB cable
DX7 USB cable
Hi guys... does anyone know where I can get a USB cable to use the DX7 with a simulator software? I have found for futaba and Sky but nothing for DX7... does anyone know??? Thanks
RE: DX7 USB cable
ORIGINAL: matador_24
AB, CANADA
RE: DX7 USB cable
RE: DX7 USB cable
AeroFly ProDeluxe...... can anyone could give me a link if it's possible????
is it 100% sure that DX7 is compatible with the JR cable?
RE: DX7 USB cable
Anyone know how to get the DX7 to work with RealFlight G3.5, period????? I have the cables that allow me to plug it in to the Interlink controller, but when I do, the controls are AFU and I can't get them sorted right. []
RE: DX7 USB cable
where did you get the cable??? can post the link please? thanks
Several cables were included in the RF G3.5 kit. One of which plugs into the back of the Interlink controller and has a plug that goes into the trainer port on the DX7.
My problem is that RF G3.5 does sense an additional controller, but the channel assignments are totally AFU and there is no apparent way of correcting this....
CA
RE: DX7 USB cable
ORIGINAL: BryFlyGuy67
The simplest way is to create a new model in the radio with the default settings. You must select fixed wing for this model, NOT HELI. The sim will take care of all the mixing and stuff, the radio is basically just sending stick position. Then just go into the controller menu, select the controller in the menu, then do the calibration. Some of the functions like throttle hold may be on a different switch but that's no big deal. Use this model whenever you use the controller with G3.5 and it will work with all the sim models.
The other way is to do all the heli mixing programming in the radio like you would with a real heli but there's a bunch of tweaking in the sim that you have to do to get it to work. And you have to program it for every sim model just like you would for all your real models. I messed around with it a little bit but it seemed like a pain so I just use the first method above.
RE: DX7 USB cable
hi i brought phoenix rc flight sim about a month ago and my dog chewed up the jr usb cable the bit befor the the black box that goes to the computer can i buy another one ?
Cheers shane
Cheers shane
RE: DX7 USB cable
there are many sellers on ebay selling the JR cable usb, just type it on ebay and you will see any options, they are about 10 bucks shipped
CA
RE: DX7 USB cable
ORIGINAL: benckie
Cheers shane
Cheers shane
