If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 8 of 8
  1. #1
    Join Date
    Aug 2006
    Plant City, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    T-REX SE V2 Auto problem.
    My new t-rex 450 se v2 flies good,but I have a problem. The heli turns to the right as soon as I hit the throttle hold switch. Is this normal? Any help will be greatly appreciated thank you all.
  2. #2
    Join Date
    Jun 2006
    Wanganui, NEW ZEALAND
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: T-REX SE V2 Auto problem.
    what radio are you using? some radios have different trim setting in thr hold and IDLE 1 and 2.
    JR 9303 2.4ghz raptor 30v2 OS.37SZ-h Raptor 903d OS .91SZ-h JR-8717 T-REX 450 SE V2
  3. #3
    Join Date
    Aug 2006
    Plant City, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I am using a dx6 withe hs-65mgs on the cyclic and a 401 and a 9650 tail servo.
  4. #4
    Join Date
    Aug 2007
    Edmonton, AB, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What is your throttle hold pitch curve like? The other thing to remember is that 450 size helis really don't auto well, the blades are too small to maintain much momentum.
  5. #5
    Join Date
    Jun 2006
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    im not too familiar with that radio but look at the trims then flick the switch and seee if the trim moves if it has digi trims. not much else i can think of. is the gyro in HH?
  6. #6
    Join Date
    Apr 2007
    Mooresville, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ORIGINAL: cameltoe
    Sounds like you have revo, tail offset set up in the hold. A little is the norm as the 450 tail does not hold that well when banging the throttle. Your gyro gain could also be too low.
    Jim
    HobbyTown USA
  7. #7
    Join Date
    Aug 2006
    Plant City, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    It doesnt really matter which mode it is in,but as soon as you hit the throttle hold it swings hard to the right.
  8. #8
    Join Date
    Jan 2006
    Newcastle, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    has it always done this or have you had it flying without the tail kicking out? does the gyro stay in the same mode when you fick the throttle switch?. The tail will always kick out from the torque effect when you kill the throttle, but the gyro should be able to stop most of it. Check all the tail linkages are smooth and check that autorotaion gear is spinning freely so theres no unneccesary drag from anything when you flick the switch
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
