T-Rex heli For all you T-Rex lovers out there, this where you can post!
t-rex 450 v2 with walkera 60 electronics
Reply
Old 08-17-2008, 03:14 AM
koolaid535
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default t-rex 450 v2 with walkera 60 electronics
Has anyone put walkera or exceed parts on a t rex 450. my question is what settings do you use (dip settings on the back of the tx.)
It worked before on my last heli. Im stuck for some reason, all i did was change the electronics from one trex to another one, and somehow its not working. Help please.
koolaid535 is offline
Old 08-17-2008, 08:50 AM
soneebee
soneebee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: t-rex 450 v2 with walkera 60 electronics
it will be a little dangerous using the walkera gear on an align heli.. its best that you use a better radio...
soneebee is offline
Old 08-18-2008, 02:33 AM
wildwilly
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you're crazy if you do it
wildwilly is offline
Old 08-18-2008, 09:14 AM
dooleyje
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: wildwilly
Yep it would be like bringing a peanut butter sandwich to a lobster dinner.
Jim
dooleyje is offline
Old 08-19-2008, 04:04 AM
koolaid535
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the response. guys
Old 08-19-2008, 11:05 AM
Archangel6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If it's all that you have I see no issue with it, I'm using the RX and TX from a Blade CP Pro for the time being until I get me 7TCHP setup.
Archangel6 is offline
Old 08-19-2008, 07:55 PM
koolaid535
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the thing is i had it setup before and switched the servos out for new ones and now everything works but the left and right are reversed, but on the walkera radio it doesn't have a reverse it has on and off. so when i get everything else to work correctly it goes the wrong direction
Old 08-20-2008, 05:32 AM
Archangel6
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ahh.. I see luckily the Eflite is reversible. It's a good set up for beginniners, very docile for hovering a CP Heli. I have a Futaba 7TCHP that I'll be installing soon.
Old 08-20-2008, 09:52 AM
soneebee
soneebee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The on and off switch on the walkera radio.. is similar to the reverse switches..its might be just the positioning of the servo on the RX that is making it run reverse
soneebee is offline
Old 08-23-2008, 03:20 PM
Phelansa
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All I can think of is to ask why you would want to hobble a great Heli with such a horrible radio system?
You are really going to struggle to tame the T-Rex sufficiently seeing as you will not be able to adjust Expo at all.
Phelansa is offline
Old 08-23-2008, 04:27 PM
Bretuk
Bretuk's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had walkera 36. Piece of junk, constantly glitching, binned it.
Bretuk is offline
Old 08-23-2008, 10:58 PM
robtangie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
koolaid,
Try switching out those two servo conections on the RX. Should fix your problem.
robtangie is offline
Old 08-24-2008, 02:13 AM
koolaid535
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will try to switch the servo's for now, but I ordered a futaba radio, it is digital so that will fix my problem, but thanks again for the response,
Reply
Display Modes
