T-Rex heli For all you T-Rex lovers out there, this where you can post!
Trex 450 rudder servo
Reply
Old 10-20-2008, 11:02 PM
nofish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Trex 450 rudder servo
Just bought my first helicopter after flying CX2 for two months(junk). I also have G4 simulator which I have not used due to computer issue so I'm in a process of upgrading the computer. I wouldn't dare to fly it until I spend time on the SIM.
Question:
Will Futaba GY401 w/ S9254 work without any issues?
I bought a package deal Trex 450 SE V2 (KX015043TA) combo version (430XL motor, speed controller 35X, 325 carbon blades, Align lipo), Spektrum DX7 w/6100, 3 Hitec 65HB, Futaba GY401 w/ S9254.
Thanks in advance.
nofish is offline
Old 10-20-2008, 11:23 PM
noobflyer01
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Trex 450 rudder servo
wow. nice package!. the 9254 is a bit too big for the trex450. that's a full size servo. that servo will work great on a 600 trex. go with the 9650 or 9257 for tail on the trex450. i'm not sure of they even have tail servo mounts for the 9254 on a rex450.
the hs65hb is good cyclic servos. only problem is that they strip in a crash. get the metal gear version (hs65mg) and your setup would be rock solid.
noobflyer01 is offline
Old 10-21-2008, 06:27 AM
Missileman
Missileman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can wait and upgrade the gearset in those hs65 servos later. They will hold up fine until your first crash. The metal replacement gears are about $10 a set.
I agree that the 9254 is too big for the 450. Perhaps you can trade it in at your LHS or sell it on Ebay or something.
I have a Futaba s9650 on my tail.
Missileman is offline
Old 10-21-2008, 09:15 AM
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 9254 will work fine. I just set up my neighbors trex 450 sa and he had one....yes it's larger, but it works fine. The 9257 would be the better choice however.
Skarn
Skarn is offline
Old 10-21-2008, 10:45 AM
UTM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9254 is a big sucker. I know a couple of guys who run them no problems but I would guess that it'll give some COG problems and your batt will have to be way forward. I am running the JR DS3400g on mine. It is superb! Smaller than the futabas and holds the tail rock solid.
UTM is offline
Old 10-21-2008, 02:00 PM
ace22459
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you buy the gyro and servo as a combo? I originally did and when I realized the servo that came with the 401 was too big I just took it back to my LHS. Payed about $220 for the combo. You can get your money back, buy the gyro alone for about $140( these prices are at my LHS), leaves you about $80 for a good digital tail servo like a JR3400G or 3500G. You end up paying about the same as the combo.
ace22459 is offline
Old 10-21-2008, 02:35 PM
nofish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for the replies. It is very helpful!
yes, I bought the gyro and servo combo. I'm thinking about buying another gyro/servo package ( 401 with 9257 ) and save this one for my next heli (hopefully 600N). Or should I just buy 9257 and share the gyro between the two? or do you recommend complete set up for each heli except the transmitter?
nofish is offline
Old 10-21-2008, 03:42 PM
ace22459
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It would be a real pain switching gyros around. I didn't know you could get a 401 combo with the 9257 servo. Thought they only came with the full size servos. Anyway, if you can get it with a micro servo, go for it.
ace22459 is offline
Old 10-21-2008, 04:26 PM
rzarikian
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try to trade it for a 9650 very nice combo though, just as mine except for the tail servo (I use a 9650) I would suggest you change the servo gears to MG if you crash, but don't change all of them, just replace the ones that broke, usually the two larger ones (that's what I did) I've noticed the servos to be a bit more precise because the play is reduced by the MG. go figure
rzarikian is offline
Old 10-22-2008, 08:39 AM
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There really is nothing wrong with using the 9254 since you already have it! As stated, I just set up my neighbors TREX 450 this weekend and it flies beautifully!
Skarn
Skarn is offline
Old 10-22-2008, 10:13 AM
nofish
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys. I will upgrade to 65MG with the kit as needed basis. I'll take Skarn's advice on the servo.
nofish is offline
Old 10-22-2008, 10:15 AM
Missileman
Missileman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I take a different tact.
Will the 9254 work, has it been done? Yes
Does it add anything extra that the 9650 or 9257 doesn't provide aside from extra weight and dificulty mounting? No
If you have to use it, use it. If you have a choice go with something that is a better fit.
Truth be told the T-Rex was really designed for an even smaller tail servo than the 9650, my first 2 had HS55 and Tower Pro 9G respectively and I had to actually buy an aftermarket mount to fit the servo upgrade.
Old 10-22-2008, 11:49 AM
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Missleman...I don't think you are taking a different tact at all.
I agree with you that if I were to buy now, I wouldn't buy a 9254 for a trex 450...I'd get the 9257....I use a 9650 now.
But given the fact he already has it...I was simply stating it will work fine.
Skarn
Skarn is offline
Old 10-22-2008, 07:19 PM
babyhuey
babyhuey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 9257 is simply awesome! Turned an inexpensive gyro into a real performer.
babyhuey is offline
Old 10-22-2008, 07:43 PM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys I got a S9650 for the tail is that a good servo or should I use something else. Thanks steve
69 roadrunner is offline
Old 10-22-2008, 09:10 PM
rzarikian
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 69 roadrunner
No don't get anything else, that servo along with a 401 makes an awesome combo for a 450. I think that's possibly the most used combination.
Old 10-23-2008, 07:32 AM
Missileman
Missileman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: rzarikian
I have a 9650 on mine along with the 401 gyro, great combo, you will be happy with it.
Old 05-12-2010, 11:31 PM
LufthansaCFI
LufthansaCFI's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
bringing a post back from the dead, but... I have a 9257 I want to put on the tail of my 450. Do you need to change the pushrod? It seems no matter where I move the gyro, the pushrod is too long to allow servo to center at 90 degrees to the rod.
LufthansaCFI is offline
Old 05-13-2010, 04:18 AM
fly 450
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you can bend the tail push rod, if it is not made of carbon, but steel, my GF is steel, I bent it to fit my 9257. Working no difference
fly 450 is offline
Reply
Display Modes
