T-Rex heli For all you T-Rex lovers out there, this where you can post!
450 longest flight time
Reply
Old 03-01-2009, 08:52 AM
paynezoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 450 longest flight time
what is the absolute longest flight time i can get, i am doing no 3d what so ever and i am just hovering and a little forward flight....... i have a zippy 2200mAH 3s 25c battery
what pinion
and blades should i use
paynezoo is offline
Old 03-02-2009, 03:38 PM
paynezoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 450 longest flight time
anyone
paynezoo is offline
Old 03-02-2009, 06:37 PM
J-MICHAEL
J-MICHAEL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: paynezoo
what pinion
paynezoo ~
I didn't realize your 12 years old, and I wish I would have discovered this hobby when I was that age you lucky dog ! I feel younger everyday though as I venture forward into this hobby. (38 now).
On your Trex 450 SA you can increase your flight time by reducing the number of teeth on your pinion. You'll get more flight time generally with a 11t than you would with a 15t for example. The lighter your heli the better also, for increased flight times... There is a lot of variables that can make a difference including what your curves are set at, the battery your using, the temperature outside, the tightness of the belt, etc. etc.
If your running the stock Align 3550 kv motor you can start with trying out an 11t pinion for starters if you haven't already and see if that helps ya some on acquiring a couple more minutes of flight time.....
Hope this may help a bit, and hopefully you'll get some more tips from others in achieving your goal.
Cheers,
~ Jeff
J-MICHAEL is offline
Old 03-02-2009, 07:14 PM
paynezoo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hey thanks i have this big heavy metal training gear i need to fix but i put an 11 tooth pinion on and i am getting longer flight time thanks again[sm=teeth_smile.gif]
paynezoo is offline
Reply
Display Modes
