T-Rex heli For all you T-Rex lovers out there, this where you can post!
Trex450SEv2 1st HOVER...THROTTLE TWITCHING!?!?!?!
Reply
Old 03-28-2009, 02:47 PM
u)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Trex450SEv2 1st HOVER...THROTTLE TWITCHING!?!?!?!
So.....Problem solved! Thank you for all your help. Once I programed the ESC and charged the pack fully i took her out for a real flight today (out side of the garage this time ) abd set the timer on the DX7 for 6 Minutes and i hovered it for the full six minutes with no problems and even went an extra minute past to 7 minutes and I could tell the pack was getting a little weak so I set her down and it was good to go! The ESC's LVC never Kicked in this time.
Thanks again guys!
P.S. It was a sunny clear blue sky, temp around 43 Degrees and about 5 to 10 MPH winds.
Thank god for RealFlight G4.5 It did save my @$$ once today
u) is offline
Old 03-30-2009, 07:23 AM
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Something must be wrong if you've been through 3 Align ESCs already! I have my original one going on two years now....I love them so much I bought another one for my plank.
Skarn
Skarn is offline
Old 03-30-2009, 03:02 PM
eaticus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 500 lb. koolaid man
I've got a similar problem. My throttle will randomly cut out for about one second, then comes back on. It does this fairly frequently, falls straight to the ground. And I know it's not the low voltage cutoff because I have experienced that and it works well. I also don't believe it's my battery since it does this at random times during flight, including the beginning of 15 minute flights with a balanced lipo.
I'm going to try and disable the esc's governor mode this weekend following the finless align esc setup video, and I'm also going to change to his recommended throttle curve. Any other suggestions about my throttle problem are welcome. Thanks.
Hi,
I had this exact problem. I thought was the ESC also. I tried several ESCs. Ranging from cheapo to CC Phx45. It all did the same thing. I finally swapped the cheapo receiver for the JR PCM receiver. All problems went away. (oh, I still fly on 72 Mhz)... It kept me mystified...
eaticus is offline
Old 03-30-2009, 03:22 PM
J-MICHAEL
J-MICHAEL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: ThAt GuY120
Thanks again guys!
So did you end up using the high cut-off voltage then ? Glad everything is working for ya now... [8D]
~ Jeff
J-MICHAEL is offline
Old 03-30-2009, 03:34 PM
u)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No I ended up going with the mid voltage cutoff setting. It was on high and I could only get about 2 minutes of hovering. With it set at mid I got 7 minutes easily and it never kicked in. Last time with it set @ mid when I did kick in,all three cells were @ 3.67v not under load. But I forgot to time that flight.
u) is offline
Old 03-30-2009, 07:24 PM
  #31
u)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
u) is offline
Old 03-30-2009, 07:49 PM
  #32
exeter_acres
exeter_acres's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
3.67 resting sounds about right....
when I put a 3s pack on the charger... if it is below 11v at the very beginning of the charge.... I feel I pushed that run a bit too hard...
exeter_acres is offline
Old 03-31-2009, 08:28 AM
  #33
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Should be vice-versa. High will give you MORE flying time, Low gives the least......on HIGH, my LVC kicks in at 3.2 per cell.....
Skarn
Skarn is offline
Old 03-31-2009, 10:40 AM
  #34
J-MICHAEL
J-MICHAEL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Skarn
Skarn
Thanks Skarn... That was the reason I had to ask him, as I was getting confused on which setting gives you more flying time in relation to when it cuts out in LVC mode. I have the Trex 500 set to mid voltage cutoff since Finless went that route also. I think I may try high VC just to test it out this way also...
Thanks...
~ Jeff
Old 03-31-2009, 04:56 PM
  #35
u)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmm I don't know, you would think that with the LVC set to high it would kick in when the voltage is higher and mid when the voltage is obviously medium and low when the voltage gets to the lowest point. Makes more sense to me that way?? Because out of the box it was set to high (3 beeps)and like I said I could only get about 2 minutes of hovering.
So high = high battery voltage left in pack
Medium = medium battery voltage left in pack
Low = low battery voltage left in pack
That's the way I understood it but I'm probably wrong.
u) is offline
Old 04-01-2009, 09:53 AM
  #36
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah bro, you are backwards....it's definitely confusing as I thought the same as you. But look at the ESC manual and you'll see what the actual voltage cutoffs are set to for the various settings....
Skarn
Skarn is offline
Old 04-01-2009, 10:45 AM
  #37
au_wozza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
According to the manual I have here for the RCE-BL35G
High setting ..when 1 cell drops to 3.2V 1st step of battery protection will kick in
mid setting ..when 1 cell drops to 2.9V 1st step of battery protection will kick in
low setting ..when 1 cell drops to 2.6V 1st step of battery protection will kick in
Cheers
Wozza
au_wozza is offline
Old 04-01-2009, 03:27 PM
  #38
J-MICHAEL
J-MICHAEL's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: au_wozza
Hi
Cheers
Wozza
That makes sense then... I remember a few guys having a tired old lipo and the LVC would kick in if the esc was set to high VC, but when they tried the low VC it would give them a few more minutes before the esc kicked in the LVC... Finally understand now ! LMAO....
~ Jeff
Old 04-01-2009, 03:47 PM
  #39
u)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: au_wozza
Hi
Cheers
Wozza
So I was right then... The higher the setting the LESS flight time u will get. Higher setting doesn't equal higher flight time it equals higher cutoff voltage. Mid is mid voltage and low means it will cut off at lower voltage.
u) is offline
Old 04-02-2009, 02:14 AM
  #40
Skarn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: au_wozza
Hi
Cheers
Wozza
Holy crap, I humbly apologize! I must have had a dyslexic moment when I read the manual!!!
I stand corrected
Skarn
Skarn is offline
Old 04-04-2009, 02:57 AM
  #41
500 lb. koolaid man
500 lb. koolaid man's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: eaticus
Hi,
You know, after thinking about it for a while, I only have this problem when I fly outdoors. Somehow, it makes a little sense that it's receiver related. Thanks anyways for the reply, it's likely the receiver even though I don't know for sure what's causing it.
500 lb. koolaid man is offline
Old 04-04-2009, 06:23 AM
  #42
au_wozza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: eaticus
Hi,
Hi
Do you still have elevator aileron and rudder control when this happens?
au_wozza is offline
Old 04-04-2009, 10:21 AM
  #43
500 lb. koolaid man
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I can not tell because it drops straight to the ground, and since I don't drop the throttle (try to auto rotation down), my guess is that nothing works for the short amount of time. Thanks.
Old 04-04-2009, 10:56 PM
  #44
au_wozza
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
If it is all controls and motor then it could be the esc is getting hot and going into thermal shut down.or if your running 2.4 ghz you might be suffering brown out
What happens is the esc also has a BEC circuit in it to power servos,gyro and RX at 4.8 or 6v. Its not rated very high and can generate a lot of heat if a servo is stalling,on the way out,or the sum total is just pulling to much current.You can do a basic check by powering up the heli with the motor disconnected(for safty reasons) then move the sticks around to the limits pretty quickly for a min or 2,then check the temp of the esc heat sink.If its pretty hot then you have a servo or gyro thats playing up or they are just all drawing to much current for the BEC rating.I always run a separate 3 to 5amp bec so if the esc ever fails I still have controls to auto or at least point the heli to the crash area
Cheers
Wozza
au_wozza is offline
Reply
Display Modes
